I'm wondering if anyone had any experience of this?
I'm currently trying to trace a slightly annoying issue on engine shutdown which essentially manifests itself in an ever so slight rumble/vibration when the engine is turned off. Initially I thought this was an issue with the EGR & ASV but after inspection they are both operating 100% & clean.
What I did notice though is that if I switch the engine off during a regen it shuts down perfectly. To me this indicates the EGR/ASV is working but also indicates an air leak in the system in the EGR system itself. The obvious thing to check are the various gaskets in the EGR system (all ok) & then the EGR cooler itself.
As I've not lost any coolant in over 15000 miles of driving I can pretty much say it's not leaking, however after a bit of researching there does appear to be an issue (mainly in the US) with the EGR cooler change over valve, in which the bearing around the lever shaft crumbles or deteriorates due to heat creating a leak which can affect emissions, mpg, create a hissing noise when driving & I'm guessing affect engine shutdown too?
The options to fix the leak is to try & strip the cooler out, fabricate a new bearing & replace it, or just fit a new one at over £300, neither a great option. I'm wondering what the EGR cooler valve actually does? The EGR valve controls the flow of the gasses so what would be the harm in disconnecting the changeover valve & blocking off the valve shaft completely, sealing off the leak?
