EGR Temp Sensor P/N
Tendaimwari
Looking for a part. Car keeps throwing the following fault code at least once a week. I have not noticed any significant dro in fuel comsumption. I think it is the sensor that is connected to the exhaus cooler that is just behind the oil extraction tube.
1 Fault Found:
10274 - EGR Temperature Sensor 1
P040B 00 [237] - Implausible Signal
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 104749 km
Date: 2018.04.05
Time: 17:41:58
Engine speed: 906.50 /min
Normed load value: 27.5 %
Vehicle speed: 0 km/h
Coolant temperature: 31 °C
Intake air temperature: 28 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 11.200 V
Unlearning counter according OBD: 40
Outside air temperature: 24.5 °C
Coolant temperature at radiator outlet: actual value: 24.8 °C
Fuel temperature: 24.0 °C
Air t EGR Clr Ds: 71.2 °C
Engine oil temperature: 29.1 °C
C Hd T t Sens: 29.5 °C
Exh.gas temp.sen 1: 44.6 °C
Readiness: 1 1 0 0 0
