Turbo jay
Leather repair specialist
Hi guys
Right noticed when I pulled up the drive after work engine was idling then started hunting,
do you think this could be a faulty pcv valve?. Also Getting fault code P0171 (system too lean blank 1)
Which I've done a search and is suggesting it could be anything from a vacuum leak,lambda sensor, or maf.
anyone had the same/similar problem? Any help appreciated.
