Hello guys!
I’ve got an 2006 Audi A3 2.0 TFSI 8P.
I understand the HPFP is a bit tappy on the TFSI engines, however from around that side of the engine, it sounds a bit louder than normal, a bit like what I can only describe as metal slapping and a little bit of smoke coming from under the rocker cover. I’ve heard the cam chain is a problem on these cars, and I’m unsure of when/if this has been changed. I’ve had an engine light pop up a couple of times, which then turns off after about an hour of driving. Not really noticing any loss in performance, and it doesn’t feel like the car is misfiring at all.
To any of you lovely people that know about these cars, does this sound like the dreaded cam chain stretching/failing or could this be as simple as a cam follower or HPFP failing?
Any help would be much appreciated!
