Hi All
I have a 2.0l TDI A4 Cabriolet with the BPW engine, on Idle the car seems to shake, after about 20 secs is smooths out, however, it comes back if quickly going from cruising speed to idle (road works etc) and lightly shakes at 1500rpm
We have fitted a second hand injector because using VCDS (measure block 13) we identified that injector 1 had a high injection figure (more than -2.8 and 2.8)
We have also adjusted the injectors so the rocker arms have about 1mm of movement with each at TDC, before there was no movement on each
It still shakes, I think since the adjustment it's worse
Does anybody have a clue what's going on?
All help much appreciated
