- Joined
- Oct 24, 2013
- Messages
- 279
- Reaction score
- 88
- Points
- 28
- Location
- Stoke on Trent and North Wales
Sorry to create a new thread but some of the errors have gone, egr errors seemed to have disappeared, now I've got these. Any ideas. Battery is fine. But its doing my head in. My local Audi mechanic has injured his self so I'm stuck.
4124 - Sensor Reference Voltage B
P0651 00 [168] - Open Circuit
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 6
Mileage: 129458 km
Date: 2017.04.27
Time: 17:32:06
Engine speed: 1232.00 /min
Normed load value: 1.2 %
Vehicle speed: 34 km/h
Coolant temperature: 76 ∞C
Intake air temperature: 13 ∞C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.820 V
Unlearning counter according OBD: 40
Exhaust gas temperature sensor 1: 254.3 ∞C
Exhaust gas temperature sensor 2: -0.0 ∞C
Exhaust gas temperature sensor 3: 213.1 ∞C
Exhaust gas temperature sensor 4: 187.3 ∞C
Shut-off timer: last engine shut-off time: 36657 s
4087 - Engine Speed Sensor (G28)
P0322 00 [036] - No Signal
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 129462 km
Date: 2017.04.27
Time: 17:38:00
Engine speed: 2297.50 /min
Normed load value: 57.6 %
Vehicle speed: 40 km/h
Coolant temperature: 83 ∞C
Intake air temperature: 15 ∞C
Voltage terminal 30: 13.380 V
Engine start: start synchronization: EPM_MODE_BACKUP_CRS
Engine start: start synchronization 2: EPM_FULL_SYNC
Camshaft speed (RPM): 1151.5 /min
Camshaft position: start of phase window: 122.41 ∞
Camshaft adaptation intake bank 1: phase position: 0.00 ∞
Camshaft slope position: 0.00 ∞
Crankshaft signal evaluation: status: TIMERMODE
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 BP HW: 8K0 907 379 BP
Component: ESP8 front H09 0090
Revision: -------- Serial number: --------------
Coding: 161544
Shop #: WSC 06335 000 00000
VCID: 081F68C9BB58BD01A1-805C
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 3
Reset counter: 113
Mileage: 129458 km
Time Indication: 0
Date: 2017.04.27
Time: 17:32:06
Freeze Frame:
Hex Value: 0x2200
Hex Value: 0x4006
Hex Value: 0x1209
Hex Value: 0x63B6
Hex Value: 0x0000
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Mileage: 129458 km
Date: 2017.04.27
Time: 17:32:06
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 129462 km
Date: 2017.04.27
Time: 17:38:00
Coding: 161544
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 113
Mileage: 129458 km
Time Indication: 0
Date: 2017.04.27
Time: 17:32:06
Freeze Frame:
Hex Value: 0x2200
Hex Value: 0x4006
Hex Value: 0x1209
Hex Value: 0x63B6
Hex Value: 0x0000
