Every full tank I have 2 occasions of rough idle and the radiator stays on
Tariq Khan
Birmingham
Hi, I have had my audi a6 c6 Le Mans 2.0 tdi le mans 2010 for over 2 years now. Car looks and runs beautiful but every full tank I have 2 occasions of rough idle (revs fluctuating up and down) and with that the radiator stays on for 20-30 mins after I stop the car. Also, car states on every full tank that I should get about 460 miles but I get between 320-350 miles per full 70 litres.
I had changed the pressure sensor last year as I went to get air conditioning refilled and it was not picking it up and the chap told me to change it. After changing the sensor, my air con got refilled which works now and my car was giving me 400 miles per tank after the pressure sensor change, so I don't know if this has anything to do with my car issues. Also, on a recent service, I noticed some green lubricant on the condensor when I was underneath the car.
Can you please recommend what I should do?
Thinking out loud.....sounds like dpf is at end of life and needing constant regens (fans will run on as part of this proccess) hence poor mpg , new aircon topup may be cooling better and shorter dpf regens restoring some mpg? and lastly green lube from aircon top up ( leak? / spill?)
