SilvercellHawk
Hi everyone I have a problem with my Audi A3 2.0 TDI 170 Quattro. The issue is with 3 exhaust gast temp sensors and today the dpf warning came on. I did a scan with VCDS and got the fault code p2o80 exhaust gas temp sensor bank 1 sensor 1. I changed this this cleared the fault and everything was ok for a week or so, the mil light came back on so I did another scan and now I have 3 egts showing as faulty including the original fault of sensor 1 bank 1. Here is the scan.
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 20.4.1.0 (x64)
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: WAUZZ License Plate:
Address 01: Engine Labels: 03L-906-018-CFF.clb
Control Module Part Number: 03L 906 018 AL HW: 03L 906 018 AG
Component and/or Version: R4 2,0L EDC H24 7764
Software Coding: 00190032042701080000
Work Shop Code: WSC 65535 000 00000
ASAM Dataset: EV_ECM20TDI01103L906018AL 003003 (AU35)
ROD: EV_ECM20TDI01103L906018AL.rod
VCID: 74EC00BEDF4216261F-8020
3 Faults Found:
8187 - Exhaust Gas Temp Bank 1 Sensor 1 (G235)
P2080 00 [237] - Implausible Signal
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 230578 km
Date: 2000.00.00
Time: 00:00:00
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 8 °C
Intake air temperature: 9 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 11.000 V
Unlearning counter according OBD: 40
Exh.gas temp.sen 1: 699.8 °C
Exh.gas temp.sen 2: -0.0 °C
Exh.gas temp.sen 3: 446.0 °C
Exh.gas temp.sen 4: 3.3 °C
Shut-off timer: last engine shut-off time: 32798 s
13811 - Exhaust Gas Temperature Sensor; B1 S3
P242B 00 [237] - Range/Performance
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 230578 km
Date: 2000.00.00
Time: 00:00:00
13812 - Exhaust Gas Temperature Sensor 4 Bank 1
P246F 00 [237] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 230578 km
Date: 2000.00.00
Time: 00:00:00
Readiness: 1 3 0 0 0
Saturday,16,May,2020,14:20:32:63801
www.Ross-Tech.com
Any help with this would be really appreciated. Thanks.
www.Ross-Tech.com
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 230578 km
Date: 2000.00.00
Time: 00:00:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 230578 km
Date: 2000.00.00
Time: 00:00:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 230578 km
Date: 2000.00.00
Time: 00:00:00
www.Ross-Tech.com
