RYuill
Today I thought I would go and do a bit more playing with VCDS. Before doing anything I performed a full scan which threw up a fault code.
15343 - Boost Pressure Regulation
P0299 00 [096] - Control Range Not Reached
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
After some Google search it seems Its a S3 common fault on the DTUK box. Its only present on those running the box at max which must be the new files, as I never had this fault with the old ones.
So for those of you who are running the new files you will need to clear the faults with VCDS before a service or any warrenty work.
I think i will be sticking the box back to the old file, clear the faults and leave it at that.
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
