Hello,
I have 4 fault codes in my 2016 A5 2.0 TDI that keep coming back periodically after clearing.
I am scanning using OBDeleven so may not be as accurate as VCDS but here is the information
The car is running fine and they don't really affect me but i would like them to not be there.
Lukasz
- Battery monitoring control module
No signal/communication
Fault code 00458
Static
166220 km
2022-03-11 7:55:31
- Voltage stabilizer
Fault code 03705
Static
166220 km
2022-03-11 7:55:31
I think these two are related because of the time stamp and nature of fault. I have the start stop/system turned off, the battery was not changed recently, the car has no issues starting even after sitting for about a week. The battery was disconnected for a short time when I was changing the steering wheel to a flat bottom one a while back. But this fault came up some time after that so not sure if that's related. Any ideas what can cause it or what i can check or measure to diagnose?
- Humidity sensor in fresh air intake duct
Faulty
Fault code 03608
Intermittent
166450 km
2022-03-13 18:17:07
- Vehicle Electrical System Control Module
Please read DTC
Fault code 00457
Intermittent
166450 km
2022-03-13 18:17:03
I think these two are also related because of the time stamp and nature of fault. They are intermittent and if the sensor in question is the one attached to the cabin air intake next to the brake fluid reservoir, then I think its not really that serious, but i would like to have it gone. I could buy a new sensor but will that fix the issue or can it be something else?
Lukasz
