Hi All,
Just starting a new thread, my first one. I have recently done a retrofit of the 3g+ in my 2010 A4 which had a Symphony active system, so quite a few bits have been changed and I have done a few of the usual Vagcom mods along with lately updating the maps and firmware to the latest 2016 version.
Now after doing all this I have done some scans and have seen a few fault codes which I can seem to work out how to fix, these are as below so please do let me know if you know how to fix the particular fault:
Sunday,08,May,2016,21:24:28:05031
VCDS Version: Release 15.7.1 (x64) Running on Windows 7 x64
www.Ross-Tech.com
Address 5F: Information Electr. Labels: 4E0-035-6xx-5F.clb
Control Module Part Number: 8R2 035 666 J HW: 8R2 035 666 C
Component and/or Version: H-BN-EU H46 0941
Software Coding: 100101000006C1EC05808F5C00000403640000030000000000
Work Shop Code: WSC 06325 000 00000
VCID: 4088D82FD390643E1D-8014
2 Faults Found:
00862 - Antenna for GPS Navigation (R50/R52) - This is probably because I am not using the OEM GPS antenna, but any clues how to clear and if it would come back after clearing?
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 6
Reset counter: 214
Mileage: 109487 km
Time Indication: 0
Date: 2016.05.03
Time: 16:10:53
Freeze Frame:
Voltage: 12.60 V
03677 - Missing Secruity/Release Code - I think this has come after the map update, I have already cleared the SVM fault code but not sure what this one is
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 203
Mileage: 109528 km
Time Indication: 0
Date: 2016.05.04
Time: 01:07:04
Freeze Frame:
Voltage: 12.70 V
Address 09: Cent. Elect. Labels: 8K0-907-063.clb
Control Module Part Number: 8K0 907 063 K HW: 8K0 907 063 K
Component and/or Version: BCM1 1.0 H25 0380
Software Coding: 690040B10134A7211701000000005F5F009D020804000141000000
Work Shop Code: WSC 06325 123 12345
VCID: 377AB3F3865E2386AC-8062
2 Faults Found:
01320 - Control Module for Climatronic (J255) - Interestingly theres no faults on the Auto HVAC module!
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 236
Mileage: 109286 km
Time Indication: 0
Date: 2016.04.29
Time: 23:11:00
03207 - Charisma Switch Module - This is since I dont have the ADS switch so it can just be ignored if I am not wrong.
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 3
Reset counter: 199
Mileage: 108700 km
Time Indication: 0
Date: 2016.04.18
Time: 19:54:00
Address 56: Radio Labels: Redir Fail!
Control Module Part Number: 4G0 035 061 Q HW: 4G0 035 061
Component and/or Version: Radio U DAB H60 0150
Software Coding: 010103020100000001
VCID: 2B529F834A169766D8-807E
4 Faults Found:
02981 - Connection between Radio and Impedance Converter 1
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 2
Reset counter: 236
Mileage: 108624 km
Time Indication: 0
Date: 2009.06.26
Time: 02:03:46
Freeze Frame:
Voltage: 12.20 V
02982 - Connection between Radio and Impedance Converter 2
Freeze Frame:
Fault Priority: 5
Fault Frequency: 6
Reset counter: 237
Mileage: 108624 km
Time Indication: 0
Date: 2009.06.26
Time: 02:03:46
Freeze Frame:
Voltage: 12.20 V
02877 - Digital Radio Antenna (R183)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 7
Fault Frequency: 1
Reset counter: 236
Mileage: 109096 km
Time Indication: 0
Date: 2016.04.25
Time: 22:41:30
Freeze Frame:
Voltage: 12.10 V
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 236
Mileage: 108624 km
Time Indication: 0
Date: 2009.06.26
Time: 02:03:46
Freeze Frame:
Voltage: 12.20 V
Address 19: CAN Gateway Labels: 8T0-907-468.clb
Control Module Part Number: 8R0 907 468 N HW: 8R0 907 468 C
Component and/or Version: GW-BEM 4CAN-M H11 0056
Software Coding: 80CF07FF00
VCID: 4A9CFA07E5ACAE6EC3-801E
2 Faults Found:
00384 - Optical Databus
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 224
Mileage: 109057 km
Time Indication: 0
Date: 2016.04.24
Time: 19:02:03
Freeze Frame:
Bin. Bits: 10000
Voltage: 12.30 V
Count: 11
Bin. Bits: 00000
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 236
Mileage: 109286 km
Time Indication: 0
Date: 2016.04.29
Time: 23:11:07
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.40 V
Count: 7
Bin. Bits: 00000
Time: 0.90 s
Any help on the above would be greatly appreciated!
www.Ross-Tech.com
2 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 6
Reset counter: 214
Mileage: 109487 km
Time Indication: 0
Date: 2016.05.03
Time: 16:10:53
Freeze Frame:
Voltage: 12.60 V
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 203
Mileage: 109528 km
Time Indication: 0
Date: 2016.05.04
Time: 01:07:04
Freeze Frame:
Voltage: 12.70 V
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 236
Mileage: 109286 km
Time Indication: 0
Date: 2016.04.29
Time: 23:11:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 199
Mileage: 108700 km
Time Indication: 0
Date: 2016.04.18
Time: 19:54:00
4 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 236
Mileage: 108624 km
Time Indication: 0
Date: 2009.06.26
Time: 02:03:46
Freeze Frame:
Voltage: 12.20 V
Freeze Frame:
Fault Priority: 5
Fault Frequency: 6
Reset counter: 237
Mileage: 108624 km
Time Indication: 0
Date: 2009.06.26
Time: 02:03:46
Freeze Frame:
Voltage: 12.20 V
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 236
Mileage: 109096 km
Time Indication: 0
Date: 2016.04.25
Time: 22:41:30
Freeze Frame:
Voltage: 12.10 V
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 236
Mileage: 108624 km
Time Indication: 0
Date: 2009.06.26
Time: 02:03:46
Freeze Frame:
Voltage: 12.20 V
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 224
Mileage: 109057 km
Time Indication: 0
Date: 2016.04.24
Time: 19:02:03
Freeze Frame:
Bin. Bits: 10000
Voltage: 12.30 V
Count: 11
Bin. Bits: 00000
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 236
Mileage: 109286 km
Time Indication: 0
Date: 2016.04.29
Time: 23:11:07
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.40 V
Count: 7
Bin. Bits: 00000
Time: 0.90 s
