FL Turbo Charger fitment on pre FL
silky16v
Anyone happen to know if the FL turbo charger is compatible with the Pre FL RS3
And if so happen to have the Part Number and Cost
Not easily.
You'd need;
Custom downpipe
Custom inlet
Custom oil and water lines
Custom waste gate
Reactions: jimojameso
Not easily.
You'd need;
Custom downpipe
Custom inlet
Custom waste gate
so not a direct fit then? wasn't aware they had changed the design of the DP and inlet i suspected the cylinder head and TIP and DP where all the same
It will fit onto the cylinder head as the runners are the same id but will need all of the above.
Reactions: Evotion
Might as well do an -Aoon- and get a higher output Turbo - either way, your warranty will be affected.
An extra 50 - 100 horses available... nice.
D
15
5K
