Flashing car to stock map help
Hi does anyone know what is a rough price to get a car flashed back to stock form currently running unicorn stage 2+. Based in Leeds
I have a 2 maps on the car which are switchable stock map and stage2+ car I just set it on the stock map or do I have to get it fully flashed with swapping the parts back to standard ? Thanks
If you have 2 maps on the car then you should be able to switch them using your cruise control stalk.. I'm not sure on the exact procedure though.
Reactions: Rayner_1704
I know how to switch maps I Just wondered if with the modded hardware being taken off and replaced with stock if the standard map would still be okay to use or if that standard map has incorporated the aftermarket hardware.
I would think even the 'standard' map will be tailored to the mods.
Best give unicorn a call.
All the tuners I know hold your original map for instances like this. The ones I know will flash it back to standard FOC, so call Unicorn and ask.
