Got forge 11mm ones on the front of mine,eibach 12mm on the rear,not sure about stance,i lowered the front with the b5 spring support plates so now the car is level whereas it was higher on the front.With the spacers on the front sits i think too wide with standard camber,but the rear with 12mm on looks spot on. With no standard camber adjustment i may take off front spacers until i get some adjustable camber arms.In the process of changing all the front end to meyle hd kit so will see what it looks like after alignment.
