- Joined
- Sep 17, 2016
- Messages
- 627
- Reaction score
- 174
- Points
- 43
Having a fuel cut problem usually when going up hill. This is the VCDs scan. Where should I start looking?
Need your help guys.
Monday,12,October,2020,14:23:43:01249
VCDS Version: Release 16.8.3 (x64) Running on Windows 10 x64
www.Ross-Tech.com
Address 01: Engine Labels: 06F-907-115-AXX.clb
Control Module Part Number: 8E1 910 115 HW: 8E0 907 115 D
Component and/or Version: 2.0l R4/4V TFSI 0030
Software Coding: 0104010A02070120
Work Shop Code: WSC 52424 006 00000
VCID: 5FCA6F378E397DBAE5-800A
1 Fault Found:
000135 - Fuel Rail/System Pressure
P0087 - 002 - Too Low - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 0
Fault Frequency: 9
Reset counter: 255
Mileage: 183244 km
Time Indication: 0
Freeze Frame:
RPM: 2202 /min
Load: 52.9 %
Speed: 63.0 km/h
Temperature: 104.0°C
Temperature: 45.0°C
Absolute Pres.: 890.0 mbar
Voltage: 12.954 V
Readiness: 0010 0000
Sent from my TA-1004 using Tapatalk
www.Ross-Tech.com
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 9
Reset counter: 255
Mileage: 183244 km
Time Indication: 0
Freeze Frame:
RPM: 2202 /min
Load: 52.9 %
Speed: 63.0 km/h
Temperature: 45.0°C
Voltage: 12.954 V
