Fuel Pressue Issues
Dear Bobby i reset the value and after this i am getting one error saying fuel too low. this is coming all the time, when i put the key and switch on. earlier it used to come in some time. we need to switch off engine and start so the MIL will go away. thanks
Do you mean you put the Pressure Control Valve on the rail?
Whereabouts in the UK are you - if you want me to take a look I can (I'm 10mins from Heathrow)
I would attempt to do an adaption on the PCV and metering unit.
Do you get low rail pressure during wide open throttle? (peak torque)
Hi, sorry for writing in a old thread. Im having this issue you are explaining with low rail pressure during WOT. As i get to 4600rpm> it sort of falls on its face and it leaves a cloud of black smoke. I also get the P008700 code.
Car is a A6 BiTdi with the CVUA engine. It has a stage 2 tune without a dpf. The tune is "smokeless" and is completely smokefree untill 4600 rpm where it seems to do something wierd haha.
cheers
cheers
Log rail pressure and IQ with RPM
Dear All - . I am from India, i had flat battery and recharged and ****** up to the car and started for running at idle. it was running fine and all ok. i went away from the car and in some time i heard a rough idle from the car and hearing the radiator kicking off to rotate with huge sound and the car stopped.
i checked the battery, its fine, the fuel pressure and flow is fine at both inlet side and at the HPP side. i have checked the compression and it clocks 21 bar. all the fuses are good in engine comportment, however the car is not starting at all. its crank well but not starting.
the radiator is keeps running when ever i switch on the ignition but not started the car. i checked the coolant temperature seasons G83 and G62 and it seems to be ok. the temperature needle in the dashboard is showing extreme right in red and if i remove the G83 and G62 wiring connections the needle is coming back to middle and radiator is stops running.
glow plugs are good, . oil level is good. below is my full auto scan from vcds. the car is still not starting. the air filter is clean, the fuel pump is clocking .5 pressure and flow is also good. i have not checked the injector yet. is there anything expert advice to check please help. the car is not starting yet and cranking well.
can you please advise with your expert help.
is there any other check i need to do to narrow down the issue? please help. no engine module error in VCDS.
thanks in advance
Sunday,08,August,2021,19:02:17:29955
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: TMBBNC1Z9AA151374 License Plate:
Chassis Type: 1Z-SK35 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBBNC1Z9AA151374 Mileage: 116440km-72352miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 1010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 1010
Address 01: Engine (J623-CLCA) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 EJ HW: 03L 906 018 BR
Component: R4 2.0l TDI H20 9977
Revision: 42H20--- Serial number:
Coding: 00110012040500080000
Shop #: WSC 10259 663 00000
ASAM Dataset: EV_ECM20TDI01103L906018EJ 003008
ROD: EV_ECM20TDI01103L906018EJ.rod
VCID: 76B5E25848406D8BA5F-8022
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels:. 1K0-907-379-MK70M.clb
Part No SW: 1K0 907 379 AK HW: 1K0 907 379 AK
Component: MK70 M MASR 0104
Revision: 00H35001
Coding: 0017665
Shop #: WSC 33361 790 00000
VCID: 7BA3F36C7FE230E3DA1-802E
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
Part No SW: 3T0 907 044 AS HW: 3T0 907 044 AS
Component: Climatronic H15 0401
Revision: 00005001
Coding: 0000001002
Shop #: WSC 73430 790 00000
ASAM Dataset: EV_Climatronic A01006
ROD: EV_ClimaAutoBasis_SK35.rod
VCID: 03538B8C0B924823921-8056
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 D HW: 1K0 937 087 D
Component: BCM PQ35 H 103 0575
Revision: 00103 AG
Coding: 4E180AB8B00508C04008008011000124410000AE422085605C0440000000
VCID: 323D1E48E42831AB497-8066
Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 28011 22 0601
Coding: 00D7B7
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 230110 05 54 0402
Coding: 0730ED
14 Faults Found:
00153 - Windshield Wiper Motor; Driver Side (V216)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 196
Mileage: 116447 km
Time Indication: 0
Freeze Frame:
Term 15 On
Voltage: 12.00 V
ON
ON
Term 50 Off
OFF
OFF
01493 - Bulb for Blinkers; Front Left (M5)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 156
Mileage: 116447 km
Time Indication: 0
Date: 2015.12.30
Time: 00:38:25
Freeze Frame:
Term 15 On
Voltage: 11.80 V
ON
ON
Term 50 Off
OFF
OFF
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 1
Fault Frequency: 69
Reset counter: 156
Mileage: 116445 km
Time Indication: 0
Date: 2015.11.02
Time: 01:51:37
Freeze Frame:
Term 15 On
Voltage: 12.10 V
ON
ON
Term 50 Off
OFF
OFF
02394 - Parking Light Left Front (M1)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 69
Reset counter: 156
Mileage: 116445 km
Time Indication: 0
Date: 2015.11.02
Time: 01:51:38
Freeze Frame:
Term 15 On
Voltage: 12.15 V
ON
ON
Term 50 Off
OFF
OFF
02395 - Parking Light Front Right (M3)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 69
Reset counter: 156
Mileage: 116445 km
Time Indication: 0
Date: 2015.11.02
Time: 01:51:38
Freeze Frame:
Term 15 On
Voltage: 12.15 V
ON
ON
Term 50 Off
OFF
OFF
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 61
Reset counter: 156
Mileage: 116445 km
Time Indication: 0
Date: 2015.11.02
Time: 01:51:38
Freeze Frame:
Term 15 On
Voltage: 12.10 V
ON
ON
Term 50 Off
OFF
OFF
01495 - Bulb for High-Beams; Left (M30)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 61
Reset counter: 156
Mileage: 116445 km
Time Indication: 0
Date: 2015.11.02
Time: 01:51:38
Freeze Frame:
Term 15 On
Voltage: 12.10 V
ON
ON
Term 50 Off
OFF
OFF
01499 - Bulb for High-Beams; Right (M32)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 54
Reset counter: 156
Mileage: 116445 km
Time Indication: 0
Date: 2015.11.02
Time: 01:51:40
Freeze Frame:
Term 15 On
Voltage: 12.10 V
ON
ON
Term 50 Off
OFF
OFF
01496 - Bulb for Fog-Lamps; Left (L22)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 50
Reset counter: 156
Mileage: 116445 km
Time Indication: 0
Date: 2015.11.02
Time: 01:51:41
Freeze Frame:
Term 15 On
Voltage: 12.10 V
ON
ON
Term 50 Off
OFF
OFF
01500 - Bulb for Fog-Lamps; Right (L23)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 50
Reset counter: 156
Mileage: 116445 km
Time Indication: 0
Date: 2015.11.02
Time: 01:51:41
Freeze Frame:
Term 15 On
Voltage: 12.10 V
ON
ON
Term 50 Off
OFF
OFF
01331 - Door Control Module; Driver Side (J386)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 196
Mileage: 116446 km
Time Indication: 0
Date: 2015.11.09
Time: 17:43:18
Freeze Frame:
Term 15 On
Voltage: 12.00 V
ON
ON
Term 50 Off
OFF
OFF
01334 - Door Control Module; Rear Right (J389)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 196
Mileage: 116446 km
Time Indication: 0
Date: 2015.11.09
Time: 17:43:18
Freeze Frame:
Term 15 On
Voltage: 12.00 V
ON
ON
Term 50 Off
OFF
OFF
00907 - Intervention load Management
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 2
Reset counter: 196
Mileage: 116447 km
Time Indication: 0
Date: 2015.12.28
Time: 00:55:23
Freeze Frame:
Term 15 On
Voltage: 11.55 V
ON
ON
Term 50 Off
OFF
OFF
01497 - Bulb for Blinkers; Front Right (M7)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 156
Mileage: 116447 km
Time Indication: 0
Date: 2015.12.30
Time: 00:38:25
Freeze Frame:
Term 15 On
Voltage: 11.80 V
ON
ON
Term 50 Off
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels:. 1Z0-919-475-V1.clb
Part No SW: 1Z0 919 475 B HW: 1Z0 919 475
Component: PARKHILFE 4K H06 0006
Revision: -------- Serial number: 66641000904029
Coding: 100001
VCID: 40D944805A84933BCF3-8014
Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
Part No SW: 6Q0 909 605 AH HW: 6Q0 909 605 AH
Component: 07 AIRBAG VW52 025 2400
Revision: 06025000 Serial number: 0037TR06BB8G
Coding: 0012343
VCID: 7DA7FD7461F63ED3E45-8028
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CP HW: 1K0 953 549 CP
Component: J0527 053 0111
Coding: 0000003
VCID: 025D8E881808412B997-8056
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective - Intermittent
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 1Z0 920 803 G HW: 1Z0 920 803 G
Component: KOMBI H06 0305
Serial number: 00000000000000
Coding: 110800
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_004_SK35.rod
VCID: 38292C6002D4DBFB773-806C
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0233
Revision: H16 Serial number: 4520K101270083
Coding: E9A07F06000202001303
VCID: 698FB924057EB27338D-803C
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 196
Mileage: 116446 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 196
Mileage: 116446 km
Time Indication: 0
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 196
Mileage: 116447 km
Time Indication: 0
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H06 0305
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8DC6280CF8B96B317-803E
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
Part No SW: 1T0 959 701 AA HW: 1T0 959 701 AA
Component: Tuer-SG 009 2114
Coding: 0004854
VCID: 76B5E25844C06D8BA5F-8022
4 Faults Found:
00120 - Outside Warning Light/Door exit Light Driver Side
00109 - Left Mirror Turn Signal Lamp (L131)
00131 - Outside Door Handle Illumination/mirror Light Driver Side
00941 - Exterior Mirror Retract Motor; Driver Side (V121)
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 68 3001
Revision: 00H17000
VCID: 313F1144ED2E0AB330D-8064
1 Fault Found:
03803 - Steering Angle Sensor for Steering Aid
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
Battery Volts: 12.1 V
PD
Temperature: 34.0°C
Count: 2
Steering Angle: 0.00°
Count: 0
SteerAng n.Init
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
Part No SW: 1T0 959 702 S HW: 1T0 959 702 S
Coding: 0004854
VCID: 48C95CA07EB4AB7B073-801C
6 Faults Found:
00121 - Outside Warning Light/Door exit Light Passenger Side
00110 - Right Mirror Turn Signal Lamp (L132)
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
00942 - Exterior Mirror Retract Motor; Passenger Side (V122)
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1Z0 035 161 F HW: 1Z0 035 161 F
Component: SWING 009 0065
Revision: 0I001001 Serial number: SKZ1Z2K8364845
Coding: 0D0004000001
VCID: 313F1144E12E0AB330D-8064
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 33361 790 1012544
VCID: 323D1E48E82831AB497-8066
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: 33331B4C173238A3421-8066
1 Fault Found:
02071 - Local Databus
End----(Elapsed Time: 01:01, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
Trying to debug this over the internet will be a nightmare - which part of India are you from?
Maybe log the rail pressure during cranking
"the radiator is keeps running when ever i switch on the ignition but not started the car." this could be bad checksum on the ECU file - did you try to tune it?
Dear Bobby - thanks for your response. I am from India Chennai West side. i did not tried anything with ECU at any time. the car was parked for a while and battery become flat. i charged it and hooked to the car and started for test run. it run almost for 20 minutes with no issue and strange, the car got off and not starting any more. from that time, this radiator and temp needle are misbehaving. i did removed the coolant sensor and if i remove the cable out both G83 and 62 the radiator stops and temp needle is coming back to center. before hooking up the battery, i did blew compressed air under the wiper motor bay where this ECM sits. cables are intact too.
thanks and appreciate your help and response
hi Boby - greetings, my car is not starting and when i checked the HPP fuel delivery, there is none. So i removed the metering device to check what signals are coming and cranked the car, the car started without metering device in the HPP. if i put this back, the car is not starting. do you have any advise what could be the issue. please advise.
hi Sir - today i tried with VCDS and if i remove the metering device the VCDS is catching up the same and reports the N290 is open circuit. if i connect it back the error is goes away. the car starts only if i remove the meter devices connectivity and hangs off if i connect it back. if i remove it the VCDS is saying fuel high pressure and shutting the engine after some time.
so will that be a metering device issue. and i wanted to confirm before i replace it. is there a way that i can check the metering device for fault? please help.
below is the latest scan report
how do i get the freeze frame data using the VCDS?
Saturday,25,September,2021,16:49:53:29955
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
03-ABS Brakes -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Revision: 42H20--- Serial number: CVN: BA7A8368
VCID: 76B5E25848406D8B8DD-8022
VINID: 91D49279306A2514411410C710D22E088E
Readiness: 0 0 0 0 1
Revision: 00H35001
Coding: 0017665
VCID: 7BA3F36C7FE230E3F23-802E
Revision: 00005001
Coding: 0000001002
VCID: 03538B8C0B924823BA3-8056
Revision: 00103 AG
VCID: 323D1E48E42831AB615-8066
Coding: 00D7B7
Coding: 0730ED
Coding: 100001
VCID: 40D944805A84933BE71-8014
Coding: 0012343
VCID: 7DA7FD7461F63ED3CC7-8028
Coding: 0000003
VCID: 025D8E881808412BB15-8056
Coding: 110800
VCID: 38292C6002D4DBFB5F1-806C
VCID: 698FB924057EB27310F-803C
Coding: 000000
VCID: 6A8DC6280CF8B96B195-803E
Coding: 0004854
VCID: 76B5E25844C06D8B8DD-8022
1 Fault Found:
Revision: 00H17000
VCID: 313F1144ED2E0AB318F-8064
1 Fault Found:
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 116447 km
Time Indication: 0
Date: 2016.02.16
Time: 02:54:01
Freeze Frame:
DD
Temperature: 38.0°C
Count: 2
Count: 0
SteerAng n.Init
Coding: 0004854
VCID: 48C95CA07EB4AB7B2F1-801C
VCID: 313F1144E12E0AB318F-8064
Coding: 0000144
VCID: 323D1E48E82831AB615-8066
Coding: 0000144
VCID: 33331B4C173238A36A3-8066
End----------(Elapsed Time: 00:57, VBatt start/end: 12.1V/12.1V)-----------
510
9
