1) Car as per sig.. should be a 50l fuel tank according to the manual, and yellow warning light should come on around 7l to go, right? So I'm a bit confused when I filled up today - managed to get about 45l in, yet I'd seen no warning light appear. Trip computer was indicating 70miles left (but then it was indicating the same when I started the journey, some 25 miles earlier). Faulty sensor or just a bigger fuel tank than indicated (by at least 2-3l)?
2) The other pattern I've spotted having strayed into low fuel regions sort of regularly, is I get a massive increase in economy during the last 10l or so in the tank. Granted, I might drive a little more smoothly when I'm (worried about) cutting it fine, but it's very little difference given I try and drive economically at other times anyway, but where on the same journey/time of year/day etc. I'd normally average an indicated low 50s MPG, when on low fuel this leaps to an indicated low 60s.
Given I calculate whole tank MPGs, I can't determine if this is just an even less accurate MPG readout than usual (it's already wildly over-generous as is) or if there really is an increase in efficiency when on low fuel. If so, why? It can't be weight, since I don't see any significant difference in MPG when I'm 1up verses carrying a 70kg passenger. Might emissions regulations be reduced in low-fuel states to boost economy?
