G28 fault !
kite
Member
East Berks
G28 speed sensor fault.
Is this easy to change?
Anyone have an idea on location on a 2.0tdi
I'm unsure of the 2.0tdi, but on the 1.9 it was a bugg er to get at. It's away in, next to flywheel. Even getting it out was a problem due to the way it was angled. What VCDS code are you getting? Symptoms?
Heres a copy of the scan....
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 7D
VIN: WAUZZZ8P84A063394 Mileage: 109850km/68257miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 G HW: 028 101 136 4
Component: R4 2,0L EDC 0000SG 5705
Revision: 12345678 Serial number: AUX7Z0C7FNK09X
Coding: 0000072
Shop #: WSC 06435 000 00000
VCID: 27562B63EF7D
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 D
Component: ESP FRONT MK60 0102
Coding: 0055942
VCID: 336ECF332BA5
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 B HW: 8P0 820 043 B
Component: KlimavollautomatH11 0130
Shop #: WSC 00000 000 00000
VCID: 2B5ED753F395
1 Fault Found:
01592 - Air Quality Sensor (G238)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 37
Mileage: 109679 km
Time Indication: 0
Date: 2011.05.19
Time: 16:14:06
Freeze Frame:
Temperature: 30.0°C
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H29 0501
Revision: 00029000 Serial number: 00000000137747
Coding: 05884F00A2141000000000000000000000
VCID: 3B7EE71303F5
Part No: 8P2 955 119 A
Component: Wischer WWS Audi350 0170
Coding: 16711696
Shop #: WSC 00000
1 Fault Found:
02071 - Local Databus
004 - No Signal/Communication - Intermittent
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
Component: Airbag 8.4ED H01 0130
Coding: 0011602
VCID: 458A81EB7531
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 009 0030
Coding: 0000012
VCID: 3064C03FDAB3
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 980 H HW: 8P0 920 980 H
Component: KOMBIINSTR. VDO H25 0080
Revision: D06 Serial number: 2247CD06000503
Coding: 0004403
Shop #: WSC 00763 210 52655
VCID: 3C7CE40F06FB
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H08 0090
Revision: 08 Serial number: 2400103724B78C
Coding: 3D0F0B48070101
Shop #: WSC 00185 210 89734
VCID: 26482667E877
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D06 Serial number: AUX7Z0C7FNK09X
VCID: 3C7CE40F06FB
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 192 A HW: 8P0 035 192 A
Component: RNS-E HIGH EU H70 0650
Revision: 00S Serial number: AUZBZ0E0900003
Coding: 0209111
VCID: 2D5AD94BCD81
2 Faults Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 93
Reset counter: 1
Mileage: 104588 km
Time Indication: 0
Date: 2010.08.30
Time: 10:40:29
Freeze Frame:
Mileage: 109710 km
Count: 2305
Clock: 07:53
16352 - Control Module - Electrical Error
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 151
Mileage: 8875 km
Time Indication: 0
Date: 2006.04.08
Time: 13:08:01
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 A
Component: Tuersteuerger. H10 0010
Coding: 0000056
Shop #: WSC 00185 210 80347
VCID: 3972FD1B09C9
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 143 L
Component: EPS_ZFLS Kl.7 0402
VCID: 336ECF332BA5
1 Fault Found:
00513 - Engine Speed Sensor (G28)
012 - Electrical Fault in Circuit - Intermittent - MIL ON
Freeze Frame:
Mileage: 9840 km
RPM: 32 /min
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H02 0040
Coding: 198800186D28050F485AC63000
Shop #: WSC 00185 210 11803
VCID: F9F2BD1BC949
Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
Part No: 1K0 907 719
Component: Neigungssensor 002 0002
Part No: 8P0 951 177
Component: Innenraumueberw.H02 0010
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 A
Coding: 0000120
VCID: 3A70E2170CCF
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0209111
VCID: 2D5AD94BCD81
2 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 93
Reset counter: 1
Mileage: 104588 km
Time Indication: 0
Date: 2010.08.30
Time: 10:40:29
Freeze Frame:
Mileage: 109710 km
Count: 2305
Clock: 07:53
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 151
Mileage: 8875 km
Time Indication: 0
Date: 2006.04.08
Time: 13:08:01
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 C HW: 1K0 963 235 C
Component: PTC-Element 0404
Revision: 00600000 Serial number:
VCID: 2B5ED753F395
End ---------------------------
The module that the G28 error is occurring in - have you looked at its mileage? Its a lot less than your current.
Any other issues - symptoms? Flashing glowplug light? Checked all electrical connections? Attempted to clear the DTCs?
Power steering warning light on.causing loss of power steering
Fault can be cleared with VCDS and returns within 10 miles.
I'm just about to put the car up on stands and have a look at the sensor connections.
Would be a good idea. Check all grounds etc too.
PM me if you want a few pics emailed detailing location - ill try to get them off elsawin. You will, however (IIRC) remove the oil filter housing. Even then it is a disaster to get it out!
Cheers, I'll PM you an email addy,
Hope its not a job for a garage...
have you followed the turn the steering to the left and hold then right and hold and centre
turning the wheel will not sort the problem I have
After a chat with a Audi tech it seems changing this sensor is not very easy.
It located behind the oil filter/cooler and the insert that the bolt screws into is known to fail.
The insert is part of the rear crank oil seal carrier,gearbox clutch and flywheel out job.
Car booked in tomorrow....
