G65 sensor
Dicktheslice
brantham
Hi I have a 13volt feed going to the connector of the g65 sensor on the signal wire and I think this is stopping the compressor from starting up. I have tested this with Vag-Com and I can get the compress to run and get all expected results the fault codes say g65 open or short to plus. And in the m/b 002 field I get the number 13 in field 1 when aircon is switched on. Can anyone advise what is the cause of this 13 volts on the signal wire
4K
imported_nadger
I
