Sportback Gearbox oil change
Terminator x
Any of the old timers on here had it done yet? Noticeable better etc afterwards? My car just coming up to 40k (!) which is when it is supposed to be changed although that does seem high to me ...
Booked in with Audi of course and they tell me it is £65!! Didn't think the technicians got out of bed for less than £500 with the RS3 :tearsofjoy:
TX.
Arcam
TX.
Wow, that must be the oil or labour cost, can't be both!
Be interested in your thoughts after the change.
Sent from my SM-N910F using Tapatalk
Rob2k68
Well-Known Member
Snap their hand off for that - fixed price Audi on an S3 was £170 when I had mine done. Went to an independent in the end as I had it done at 30k miles but I’m certain it was noisier afterwards possibly thinner oil.
Sent from my iPhone using Tapatalk Pro
bqik
I change the oil each 15000km and Haldex- DSG each 30000km
no difference noticeable.
regards
AudiNutta
Moderator
Staff member
Moderator
Gold Supporter
Nah £65 isn’t right, my Dads A4 S Tronic is booked in next week and it’s around £300!!
Audi said to be very critical on it being done for the gearbox, from our service advisor.
T
T-800
Guest
When I changed the DSG oil on the GTD it cost me £100 for the 6 litres of oil & filter......VW do it for £170
It cost me around £170 at Stafford Audi when they changed my DSG fluid / filter on the 8P RS3.
DW81
I think I know what I will be doing come s tronic oil change time, £100 for oil and filter is a pretty good price and a few hours of your time
DW81
Do you need vcds to monitor the oil temps mate when doing this work?
T
T-800
Guest
Yes you do...min of 45-50deg before dropping the fluid.
Using advanced measuring values in VCDS.
Fatbloke
Thread revival !!!
What's the reason for checking the gear oil temp? How do you do this with VCDS?
What oil is required for the gearbox on an A3 2016 8v manual 6 speed 150tdi s-line quattro?
Apart from gearbox oil and Haldex oil, is there any other oil required on the transmission?
Are there any how to documents or videos for vcds and the oil changes (I know how to do the haldex unit already) ?
T-1000
Well-Known Member
Gold Supporter
Thread revival !!!
Audi specify a temp range as oil expands as it gets warmer.
You have a ‘window’ with the temp range so as to allow any excess oil to drain out before putting the drain plug back in.
With VCDS go into 02 auto trans and select Advanced measuring values.
Scroll through the list until you find transmission fluid temp and tick the box to select it, you’ll see it come up in the main screen along with the current temp.
As yours is a manual the procedure will be different so it may be worth seeking a tutorial and for oil spec etc try Opie oils online and type in your reg to get the info you need.
