Originally this was the problem.
No awd, but now I have the esp light on the dash constantly on, when I removed the pump the earth strap came away in my hand, green and corroded..... Any idea what is going on, what I need look at, I've done a complete scan with vcds, here are the faults.
awd not working, after only 8,000 miles pump clogged, cleaned gauze new oil ,then earth strap snapped.......tried earthing but still same,now esp on too in dash.
Code:
Thursday,23,December,2021,16:46:32:22644
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: WAUZZZ8U6ER044674 License Plate: Q3
Mileage: 142210km-88365mi Repair Order:
Chassis Type: 8U-AU21 (8U0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 42 44 46 52 53 55 5F 62 72
VIN: WAUZZZ8U6ER044674 Mileage: 142210km-88365miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: Cannot be reached 1100
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 CM HW: 03L 906 018 ES
Component: R4 2.0l TDI H28 9977
Revision: 41H28--- Serial number: CVN: E90C9A75
Coding: 00190012043701080000
Shop #: WSC 00780 002 1048576
ASAM Dataset: EV_ECM20TDI01103L906018CM 003005
ROD: EV_ECM20TDI01103L906018CM.rod
VCID: 77ABE927EF48C3F396B-8022
VINID: 9D196AAAA22519588010418710726693E9
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 5N0-614-109-C6.clb
Part No SW: 5N0 614 109 AT HW: 5N0 614 109 AT
Component: J104 C6 450M VD46 0150
Revision: --H07--- Serial number: 00000007490197
Coding: 0056711
Shop #: WSC 00049 770 00156
VCID: 7DA7FB0FC1F4E9A3CC7-8028
3 Faults Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 6
Fault Frequency: 3
Reset counter: 70
Mileage: 142219 km
Time Indication: 0
Date: 2021.12.23
Time: 16:03:27
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 14.25 V
Bin. Bits: 00011111
Count: 185
Hex Value: 0x0000
01324 - Control Module for All Wheel Drive (J492)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 3
Reset counter: 70
Mileage: 142219 km
Time Indication: 0
Date: 2021.12.23
Time: 16:03:28
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 14.25 V
Bin. Bits: 00011111
Count: 256
Hex Value: 0x0000
01325 - Control Module for Tire Pressure Monitoring (J502)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 70
Mileage: 142219 km
Time Indication: 0
Date: 2021.12.23
Time: 16:03:38
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 14.25 V
Bin. Bits: 00011111
Count: 191
Hex Value: 0x0000
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8U0 820 043 D HW: 8U0 820 043 D
Component: E87 Klimavoll 0100
Revision: 00H04000 Serial number: 8U0820043D
Shop #: WSC 00000 000 00000
VCID: 323D1833482AE6DB615-8066
1 Fault Found:
01333 - Door Control Module; Rear Left (J388)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 17
Reset counter: 107
Mileage: 140244 km
Time Indication: 0
Date: 2021.11.01
Time: 09:39:56
Freeze Frame:
ON
Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb
Part No SW: 8X0 907 063 N HW: 8X0 907 063 N
Component: BCM PQ35 M 112 0771
Revision: AG112771
Coding: 0E000A2CA807F1C0201841C021000D4C53FF84AA216F912BE408878400C5
Shop #: WSC 00049 770 00008
VCID: 47CB59E7DFA8737326B-8012
Subsystem 1 - Part No SW: 8U2 955 119 HW: 8U2 955 119 Labels: 1KX-955-119.CLB
Component: WWS316 131001 H36 0085
Serial number: 131003114119
Coding: 0047F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 21840414
Coding: 02006E
Subsystem 3 - Part No: 8X0 951 177
Component: DWA-Sensor H0 H01 0020
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 10: Park/Steer Assist (J446) Labels:| 8X0-919-475.clb
Part No SW: 8X0 919 475 N HW: 4H0 919 475 AG
Component: PARKHILFE 8K H01 0050
Revision: 11001001 Serial number: 61061328401175
Coding: 08C205
Shop #: WSC 00049 770 00119
ASAM Dataset: EV_EPHVA18AU21X0000 003006
ROD: EV_EPHVA18AU21X0000_003.rod
VCID: 51FF77BF216CBDC378F-8004
Address 15: Airbags (J234) Labels:| 8X0-959-655.clb
Part No SW: 8U0 959 655 B HW: 8U0 959 655 B
Component: AirbagVW-AU10 H08 0520
Serial number: 003LRR06LFWN
Coding: 30393132313030303030554A305238553053
ASAM Dataset: EV_AirbaAU10SMEAU316 001005
ROD: EV_AirbaAU10SMEAU316_001.rod
VCID: 46D554E3D8226A7BDDD-8012
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.V H02 ----
Serial number: 3496KSME55753F29ZZZ4
Front Passenger's Side Airbag Crash Sensor:
Subsystem 2 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.V H02 ----
Serial number: 3506KSME31172629ZZZJ
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 3 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME2F561D29ZZZ%
Passenger side rear thorax airbag crash sensor:
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME592D2629ZZZ
Crash sensor for front airbag: driver side:
Subsystem 5 - Part No SW: 8U0 959 651 HW: 8U0 959 651
Component: F.Sens.Fahr H02 ----
Serial number: 3555USME52703226ZZZT
Address 16: Steering wheel (J527) Labels:| 8X0-953-569.clb
Part No SW: 8X0 953 521 D HW: 5K0 953 569 AE
Component: LENKS.MODUL 016 0140
Revision: FF010018 Serial number: 20131106301207
Coding: 1084204000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 3D273B0F8DF429A38C7-8068
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 8U0 951 528 G HW: 8U0 951 528 G
Component: E221 - MFL H08 0010
Address 17: Instruments (J285) Labels:| 8X0-920-xxx-17.clb-SRI1
Part No SW: 8U0 920 980 E HW: 8U0 920 980 E
Component: KOMBI_MEDIUM H01 0330
Serial number: 00000000000000
Coding: 42CF01
ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
ROD: EV_Kombi_UDS_VDD_AU10.rod
VCID: 3E253C0380F232BB95D-806A
Address 19: CAN Gateway (J533) Labels: 8X0-907-468.clb
Part No SW: 8U0 907 468 Q HW: 8U0 907 468 G
Component: GAT 4CAN 1L M H13 0063
Revision: 1P120037 Serial number: 3741P13A110B80
Coding: FBCF1A5A000100610353
VCID: 50F972BB2AE6B4CB771-8004
Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
Component: J367-BDM H07 0180
Serial number: 30289J04341491273416
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 13290001793021200181
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 70
Mileage: 142219 km
Time Indication: 0
Date: 2021.12.23
Time: 12:37:44
Freeze Frame:
Bin. Bits: 11111
Voltage: 14.60 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Address 22: AWD
Cannot be reached
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Component: IMMO H01 0330
Serial number:
Coding: 000002
ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04113
ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb
Part No SW: 8X0 959 793 H HW: 8X0 959 793 H
Component: TSG FA H10 0415
Revision: -------- Serial number: --------------
Coding: 011E06200001000000
VCID: 52FD78B324EAC6DB415-8006
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 5N0 909 144 R
Component: EPS_ZFLS Kl. 296 3501
Revision: 00H22000
VCID: 40D942FBF686444BE71-8014
Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb
Part No SW: 8X0 959 792 H HW: 8X0 959 792 H
Component: TSG BF H10 0415
VCID: 51FF77BF21ECBDC378F-8004
Address 53: Parking Brake Labels: 3AA-907-801.clb
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000001533812
Coding: 0025166
VCID: 36352423A442FAFB4DD-8062
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
Component: ****LWR12**** H02 0020
Serial number: 131023-0002-107
Coding: 1157A41010002500
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic_AU21.rod
VCID: 42DD48F3F40A565BF15-8016
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 8U0 035 193 C HW: 8U0 035 193 A
Component: RMC Cnct Nav H54 0801
Coding: 0101060002C153070823020103010000000000
VCID: 3537232FB544F1E3447-8060
Subsystem 1 - Part No: 8X0 919 884 F
Component: P23-50-13.06 0001
Subsystem 2 - Part No SW: 8U0 919 603 HW: 8U0 919 603
Component: DUBasic AU316 H41 0018
Serial number: AUZ8ZDD0604MJ7U
Address 62: Door, Rear Left (J388) Labels:. 8X0-959-795.clb
Part No SW: 8X0 959 795 C HW: 8X0 959 795 C
Component: TSG HL H07 0415
Coding: 010E06200001000000
VCID: 4FFB71C737D8AB336EB-801A
Address 72: Door, Rear Right (J389) Labels:. 8X0-959-795.clb
Component: TSG HR H07 0415
End----(Elapsed Time: 01:37, VBatt start/end: 12.5V/12.0V. VIgn
- 16671 – Pump for Haldex Clutch – C1112 04 [008] Internal System Fault (faulty pump AND ecu needs repair)
Code:
www.Ross-Tech.com
Coding: 0056711
3 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 70
Mileage: 142219 km
Time Indication: 0
Date: 2021.12.23
Time: 16:03:27
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 14.25 V
Bin. Bits: 00011111
Count: 185
Hex Value: 0x0000
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 70
Mileage: 142219 km
Time Indication: 0
Date: 2021.12.23
Time: 16:03:28
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 14.25 V
Bin. Bits: 00011111
Count: 256
Hex Value: 0x0000
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 70
Mileage: 142219 km
Time Indication: 0
Date: 2021.12.23
Time: 16:03:38
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 14.25 V
Bin. Bits: 00011111
Count: 191
Hex Value: 0x0000
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 17
Reset counter: 107
Mileage: 140244 km
Time Indication: 0
Date: 2021.11.01
Time: 09:39:56
Freeze Frame:
ON
Revision: AG112771
Coding: 0047F7
Coding: 02006E
Coding: 08C205
Coding: 1084204000
Coding: 42CF01
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 70
Mileage: 142219 km
Time Indication: 0
Date: 2021.12.23
Time: 12:37:44
Freeze Frame:
Bin. Bits: 11111
Voltage: 14.60 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Address 22: AWD
Cannot be reached
Serial number:
Coding: 000002
Revision: 00H22000
Coding: 0025166
