Haldex or not ?
Audis32015
Hi Guys
2015 RS3
Jerky on some occasions and a bit of a rough ride at the moment
When the car goes over a speed bump or hits a road bump the traction light flashes
No codes showing for Haldex or anything to be honest (OBD eleven )
Any advice something isn’t quite right ...
Also I have the famous exhaust rattle which is going back into Audi for but I need advice reference the Haldex or what else it could be
DW81
Traction control kicking in is normal does it if I go over a speed bump to fast, I’m still on the pzeros so don’t know f this makes a difference. As for you haldex mate someone will know doubt more technical will tell you.
T
T-800
Guest
When you say it's jerky on occasions what exactly are you experiencing ?
Traction control on the 15/16 cars can be like that over speed bumps/pot holes......had it now and again on mine.
Audis32015
Just not smooth to summarize ...
I feel sometimes the car is not on full power/torque and noticed this when I was going over bumps and heard Haldex is a common problem
When the car is pulling away after start up I feel its not pulling on all 4 wheels and sometimes over reeving but I could be wrong ...
DW81
Not an expert mate but that is definitely not right. Have you tried doing the same thing in manual mode? Need to get the car hooked up to vcds to see what’s triggering the traction control module
Audis32015
Have a road test with Audi later today so
Will keep you posted
Still under warrenty so I’m not concerned but to be honest I just want to know what it is as it’s driving me crazy !!
T
T-800
Guest
Are the tyres all good ? Pressures where they should be ?
In your clip above is that when you go over speed bumps?
Audis32015
All good two brand new tyres on front, rear @6mm also all PSI checked all round and nothing.
Yes just two normal not high etc speed bumps - Not putting the foot down just gentle. IT also happens on general road bumps etc
Audis32015
Update
Master tech came out watched my video and he has confirmed there is an issue but didn’t commit to what the problem is. Mention the diff, clutch oil getting contaminated ..,..
But booked it in to get repaired
Also the exhaust flaps are rattling so rear ehiast needs replaced
Finally getting somewhere
Audis32015
Update even more of a laugh
Said the tech was also able to get the same fault to display
Resolution was that the coding was incorrect ? Not sure how or why but Audi but it back to standard factory for the gateway module and they said it is resolved
Car comes home today still happening !!!!!!
On a plus exhaust had been changed due to
Flap rattle
Aoon_M
What tyres do you have?
Slowracer
Could the haldex be more prone to confusion with the 2 different tyre profiles.
May be interesting to see if others having similar problems also have the optional 255 up front.
Audis32015
Yeah welcome everyone to chip in - In all honesty they really don’t have a clue what’s causing it.
But the good thing is I have in the paper work they replicated the fault themselves so something will be getting changed
If it is the tyre profiles then I guess it’s a challenge back to Audi as this is the config I bought the car with and also they changed the tyres themselves and put these ones on.
But if anyone has an ideas let me know or past expierence of this
AB RS3
2018 Ara Blue RS3
A lot of people have got the staggered wheel setup including myself with no issues present.
Magan
Any update on this? I have a similar issue in that ESP kicks in if i go WOT from 3rd and 4th gear, power gets cut. If i go flat out from a dig, theres no issues with ESP flashing and cutting power.
Powerenhancer
Have you tested with the TC fully disabled?
Magan
It seems to do the Same with TC fully disabled. Feel a slight power cut higher up the RPM range in those gears.
