Hade a problem with the car about 2 weeks ago, it had a bang under the car and it was like the car was on the brakes, it was hard to move, had it towed to Audi workshop but the didnt find any problem, and the test drived it and the it worked fine for a week and now this Grinding noise appered. Now I will to try to fixit my self!
I think it is the transfercase is going bad?. When i turn the propshaft(axel to rear diff) I notice a sound like it something loose in in the TC, like a small metal object(ballbearing?) drops in the case by the connection to axel (to rear diff). But there is no play on the axels on the TC.
Have any one changed the transfercase? Would be nice with some tips/trix how to remove it. Figuered out it has 4 bolts with 6mm hex . Seen that there is a 6mm vwtool that is 355mm long with 6mm hex, (I will build the tool my self.)
Guess I need to remove hole CV-axel too on passager side?
Does it slide out from the passagerside or need to lower/lift engine?
Can not find any Workshop Manual for the Quattro modell. ( I have a A3 2011 2.0 tdi Quattro)
