Do anyone else headlight washers fail to return back into the bumper? Every time I use them they're still sticking out the bumper when I get home...
There must be a fuse somewhere that can be pulled?
Use VCDS! No need to cut any wires or mess on with the fuses. Takes less than 2 minutes to do.
Anyone have a clear photo marking which bits to remove/ dremel?
Common fault and a really easy fix with a dremel, first you need to return the washer back in to the bumper and if poss keep hold of the flap and you will see 2 strips of plastic that stand proud of the flap basically get rid of them with a file or dremel. Job done
I posted some pics they are one the first page, check them out they should give enough of a picture for you, I think.I have the same problem with mine- I opened the flap but can't see the strips you mention the stand proud- there is piece that the washer nozzle pushes against but it's smooth on all sides- I can't see any ridges- can you help? Thanks
Yes the grey line is where it was filed off, try get a couple of pics up & I will do my best to help.
