Headlights.
Dr_Rick
Edinburgh
Ok everyone, be nice.
I have a 59/2009 S3 Sport acknowledge and the DRL strip on the drivers / offside is starting to play up and throw a bulb error.
I'm going to work on the premise that it's not fixable and that a replacement headlight unit is needed.
I think I've got xenon as there are silver ballast boxes under each lamp unit. I presume I don't have bi-xenon, but please clarify my assumptions.
I've checked with TPS who have quoted £394+VAT. While that is what it is, I have a couple of questions:
1) Am I right that I need a new headlight?
2) Is it basic xenon?
3) Is there a sensible alternative to TPS?
Thanks in advance.
Rick
Sent from my ONEPLUS A5010 using Tapatalk
Either you have bixenon or bixenon adaptive, denoted by part number & the headlight side colour.
Ping up a pic then can advise.
New headlight if drl strip has gone, its a known fault unfortunately.
Reactions: KKOG
Thanks for the pointer.
I'll go check in a minute.
I'm 80-90% certain I don't have anything adaptive. That being said, I didn't think I had bi-xenon so it's entirely possible I'm completely wrong.
New headlight muwt be setup diagnostically. Whereabouts are you located?
No problem. I'm sure I can find someone up here to do it. I do have a friend that has a VCDS setup. Just need to find the codes to get it all plugged in if that's what I need to do.
Offside Headlight Sticker
This is the sticker on the offending headlight. Which is the part number? I've tried a couple of combinations of what I can see there in TPS and don't get any results.
