Hi there I’ve had a front driver side brake callipers seize on me does anybody know where to get a new set? Nowhere seems to stock them that I can find help much appreciated
I would try and remove the front and check and grease the sliders. Fronts are easier to check tbh. Jack the front right up(jack mode) remove the wheel and full lock. Check few YT videos buddy trust me it’s fairly easy for a semi competent DIYer. If not comfortable then leave it to the pros. Don’t take the brake fluid pipe off as you will need to bleed the system then.
