help coding PLEASE
david-a3
Hello
Help please I'm a little desperate
Turning the sensor is calibrated only, which does not bother me
The fault I have are the following, that happen to me since I made the change at ECU 17 to 30 bytes.
-The Steering wheel buttons light up but do not go
"I left reverse light appears melted when my car only takes one to the right of the box was a distribution guess Sportback
'I appears both beam emitted, and both work, I suongo that the ECU should carry coded bi-xenon or something
-The Mirror photosensitive does not light, since I put ecu, and which is activated in bit 18
Uncoded him or Bluetooth browser, which is my fatal ....
Thank you very much in advance
00-steering angle sensor - Status: OK 0000
01-Engine - Status: OK
0000
Brakes ABS-03 - Status: Malfunction 0010
08-Auto HVAC - Status: OK 0000
09-Cent. Elect. - Status: Malfunction 0010
15-airbags - Status: OK 0000
wheel 16-Address - Status: OK 0000
17-Instruments - Status: OK 0000
19-CAN Gateway - Status: Malfunction 0010
25-immobilizer - Status: OK 0000
37-navigation - Status: Malfunction 0010
42-Door Elect, Driver - Status: OK 0000
44-Assist Steering - Status: Malfunction 0010
46-Central Conv. - Status: OK 0000
47-Sound System - Status: 1100 can not be reached
52-Door Elect, Pass. - Status: OK 0000
55-xenon Range - Status: OK 0000
56-Radio - Status: Malfunction 0010
57-tuner TV - Type: No registered 0011
76-Park Assist - Status: OK 0000
77-Phone - Status: OK 0000
7D-Aux. Heat - Status: OK 0000
-------------------------------------------------- ----------------------------- Address 01: engine labels: 03G-906-016-BKD.lbl from the SW : 03G 906 016 G HW: 028 101 136 4 components: 2.0L R4 EDC G200SG 5705 version: 12345678 serial number: AUX7Z0C9FNV0HF Encoding: 0000072 Shop #: WSC 00982 572 55167 VCID: 275D1D1E964D1926F59-8072
No fault code found. Preparation: 0 0 1 1 1
Start Self-diagnosis VCD Thursday 03 October 2013.21: 50: 26: 40973 Page 2
VIN: WAUZZZ8P04A101233 License Plate:
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl Part No: 1K0 907 379 K Component: FRONT MK60 ESP 0103 Coding: 0023174 Shop #: WSC 06435 000 00000 VCID: 3A7BD46A75FF94CE9A7-806F
1 Fault Found:
00778 - Steering angle sensor (G85) 005 - No or incorrect adjustment / adaptation Basic
Address 08: Auto HVAC Labels: 8P0-820-043.lbl from SW: 8P0 820 043 Q HW: 8P0 820 043 Component Q: KlimavollautomatH18 0300 Version: 036659 Serial number: 8P0820043Q Shop #: WSC 06314 000 00000 VCID: 806F 3A7BD46A75FF94CE9A7-
Start Self-diagnosis VCD Thursday 03 October 2013.21: 50: 26: 40973 Page 3
Address 09: Cent. Elect. Tags: 8P0-907-279-30-H.lbl partial No SW: 8P0 907 279 K HW: 8P0 907 279 K Component: H54 Bordnetz SG-2501 Version: 00H54000 Serial Number: 00000008296987 Encoding: 0000000000 E78ADB00821410008000001C00000000000000000000000E00 Shop #: WSC 06314 123 08192 VCID: 4581B7960C01EB36E75-8010
Subsystem 1 - Part number: 8P1 955 119 Tags: 1TX-955-119.CLB components: Wischer WWS Audi350 0130 Coding: 16711696 Shop #: WSC 06314
Subsystem 2 - Component: Lin-slave Error 02
3 defects observed:
02092 - Enabling Heated Seat 009 - open or shorted to ground Freeze Frame: Fault Status: 01101001 Fault Priority: 5 Fault Frequency: 1 Reset counter: 231 Mileage: 174471 km Time Indication: 0 Date: 07.24.2016 Time : 5:01: 00
Freeze Frame: ON Voltage: 11.95 V ON ON OFF OFF OFF
02071 - local data bus 004 - No Signal / Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 174471 km Time Indication :: 231 Mileage 0 Date: 24.07.2016 Time : 5:01:00
Start Self-diagnosis VCD Thursday 03 October 2013.21: 50: 26: 40973 Page 4
ON OFF OFF OFF
01520 - The rain and light sensor recognition (G397) 004 - Freeze Frame No Signal / Communication: Fault Status: 01100100 Fault Priority: Failure of frequency 2: 1 Reset counter: 174471 km Time Indication :: 231 Mileage 0 Date: 7/24/2016 Time: 5:01:00
-------------------------------------------------- ----------------------------- Address 15: Airbags Labels: 8P0-959-655-84.lbl from SW: 8P0 959 655 F HW: 8P0 959 655 F Component: Airbag 8.4ED H01 0130 Coding: 0010602 Shop #: WSC 06435 000 00000 VCID: 4581B7960C01EB36E75-8010
-------------------------------------------------- 16 ----------------------------- Address: Address: labels wheel-F.lbl 8P0-953-549 partial Without SW : 8P0 953 549 F HW: 8P0 953 549 F Component: J0527 H38 0070 Coding: 0002141 Shop #: WSC 02391 785 00200 VCID: 4189A3861829C716DBD-8014
Subsystem 1 - Part Number: XXXXXXXXXXXX Component: E0221 H06 0030
Start Self-diagnosis VCD Thursday 03 October 2013.21: 50: 26: 40973 Page 5
Address 17: Instruments Tags: 8P0-920-xxx-17-MY7.lbl from SW: 8P0 920 930 F HW: 8P0 920 930 F Component: KOMBIINSTR. VDO H25 0110 Version: D07 Serial Number: 2249CD07022304 Coding: 0004103 Shop #: WSC 30320 933 00031 VCID: 3561C7565CE17BB6775-8060
-------------------------------------------------- ----------------------------- Address 19: labels on cans gateway: 1K0-907-530-V1.clb from SW: 1K0 907 530 B HW: 1K0 907 951 Component: gateway H08 0090 Revision: 08 serial number: 24001039155BA3 Encoding: 7D0F0FCA070100 Shop #: WSC 06435 123 12345 VCID: 2643101A9147002ECEF-8073
2 faults found:
00463 - Control Module Package Digital Sound (J525) 004 - No Signal / Communication Freeze Frame: Fault Status: 01100100 Priority Fault: Fault frequency 2: 1 Reset counter: 231 Mileage: 174471 km Time Indication: 0 date: 24/07/2016 Time: 5:03:01
01044 - Control Module incorrectly coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 1 Fault Frequency: 1 Reset counter: 231 Mileage: 174471 km Time Indication: 0 Date: 07/24/2016 Time: 05: 3:01
Start Self-diagnosis VCD Thursday 03 October 2013.21: 50: 26: 40973 Page 6
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb from SW: 8P0 920 930 F HW: 8P0 920 930 F Component: KOMBIINSTR. VDO H25 0110 Version: D07 Serial Number: AUX7Z0C9FNV0HF Shop #: WSC 23234 000 1048576 VCID: 3561C7565CE17BB6775-8060
-------------------------------------------------- ----------------------------- Address 37: navigation labels: 8E0-035-192-RNSE.lbl from the SW : 8P0 035 193 G HW: 8P0 035 193 G Component: RNS-E PU 0220 H06 EU version: 0000012S serial number: AUZBZ7LD213996 Encoding: 0229712 Shop #: WSC 21897 133 86498 VCID: 3467FA52579B62BE40B-8061
2 faults found:
00858 - Connection; Radio Intermediate Frequency (IF) amplifier output antenna 007 - short to ground Freeze Frame: Fault Status: 01100111 Fault Priority: 5 Fault Frequency: 1 Reset counter: 231 Mileage: 174471 km Time Indication: 0 Date: 24 / 07/2016 Time: 05: 03: 58
Freeze Frame: Mileage: 174,470 km Count: 2407 Clock: 5:03
01044 - Control Module incorrectly coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 231 Mileage: 174471 km Time Indication: 0 Date: 24/07/2016 Time: 05: 3:36
Start Self-diagnosis VCD Thursday 03 October 2013.21: 50: 26: 40973 Page 7
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl Part No: 8P0 959 801 A Component: Tuersteuerger. H10 0010 Coding: 0000120 Shop #: WSC 06435 000 00000 VCID: 3979CB6670F99FD693D-806C
-------------------------------------------------- ----------------------------- address 44: steering assistance Tags: 1Kx-909-14x-44.clb Part No: 1K1 909 144 Component E: EPS_ZFLS Kl.10 1202 Shop #: WSC 00000 000 00000 VCID: 2D51EF36B4B133760F5-8078
2 faults found:
02546 - Steering stop limit 005 - No or incorrect adjustment / basic adaptation - MIL ON Freeze Frame: Mileage: 4440 km Temperature: 44.0 ° C Voltage: 12.10 V Voltage: 11.80 V
00778 - Steering angle sensor (G85) 000 - - - MIL ON Freeze Frame: Mileage: 4440 km View Count: 1 Steering angle: 0.00 °
Address 46: Central Conv. Tags: 8P0-959-433.lbl Part No: 8P0 959 433 B Component: KSG H02 0040 Coding: 008800186D6C850F484A016000 Shop #: WSC 23234 123 104857 VCID: 3B75D16E7AC5ADC6811-806E
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Start Self-diagnosis VCD Thursday 03 October 2013.21: 50: 26: 40973 Page 8
47 Address: you can not reach Sound System
Address 52: Door Elect, pass. Tags: 8P0-959-802-MIN1.lbl Part No: 8P0 959 802 A Component: Tuersteuerger. H10 0010 Coding: 0000120 Shop #: WSC 06435 000 00000 VCID: 3A7BD46A75FF94CE9A7-806F
-------------------------------------------------- ----------------------------- Address: 55 xenon Range labels: 8P0-907-357.lbl Part No: 8P0 907 357 A component: dynamische LWR H01 0010 Revision: 00000000 serial number: Encoding: 0000001 Shop #: WSC 06435 000 00000 VCID: 387FCE624BF386DE6C3-806D
Start Self-diagnosis VCD Thursday 03 October 2013.21: 50: 26: 40973 Page 9
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl from SW: 8P0 035 193 G HW: 8P0 035 193 G Component: RNS-E PU 0220 H06 EU Version: 0000012S Serial number: AUZBZ7LD213996 Encoding: 0229712 Shop #: WSC 21897 133 86498 VCID: 3467FA52579B62BE40B-8061
2 faults found:
Address 57: TV tuner can not be reached
Start Self-diagnosis VCD Thursday 03 October 2013.21: 50: 26: 40973 Page 10
Address 76: Park Assist Tags: 8P0-919-283.lbl from SW: 8P0 919 283 HW: 8P0 919 283 Component: Parkhilfe 4-Kan H06 0020 Coding: 0000003 Shop #: WSC 06435 000 00000 VCID: F8FF8E628B73C6DE2C3-80AD
Address: 77 Labels Phone: 8P0-862-335.lbl from SW: 8P1 862 335 A HW: 8P1 862 335 Component: FSE_256x BT H44 0660 Revision: 00000000 Serial Number: 00000005546165 Coding: 0011855 Shop #: WSC 00000 000 00000 VCID: 3561C7565CE17BB6775-8060
Address 7D: Aux. Heat tags: 1K0-963-235.lbl from SW: 1K0 963 235 C HW: 1K0 963 235 C Component: Element PTC-0404 Revision: Serial number 00600000: Shop #: WSC 00000 000 00000 VCID: 2B55E12E8AA53D46111 -807E
david-a3
thanks for your answer. It has more errors and I managed to solve by searching the Internet , but those have already looked wiring and everything and not . hope help thanks
