Only purchase a 2010 a4 avant 2ltr tdi 143hp.. It seems to be heavy on fuel got 117 miles from half a tank. I'm getting code p246f00 and can't locate it. Any help appreciated..
The Sensor itself is located after the DPF. It looks like a pig to get to. Manual reckons you have to drop the gearbox mount and remove the center pipe.
Have the EGT Sensor 4 Bank 1 error coming up on my VAGCOM wiht the engine light in the dash. A reset lasts for a bit then it comes back.
Has anyone got a link for the work involved to get to and replace this part? Also doesa someone have a part number for the 2010 A4 B8 2.0tdi CAGA?
thanks.
