Urgent Help Required
A few days ago the rear wiper and washers failed on my Audi A3 8P Sportback. With the help of this forum this was diagnosed and rectified by replacing a relay located under the steering wheel area.
A few hours ago everything was working ok and now the indicators, wipers, washers, horn, main beam, MFSW controls have all stopped working.
Can anyone out there help, I have done a search and there are a few possibles however nothing specific to this that I have found.
Any help / suggestions are appreciated.
Please find below a full scan and ignore the glow plugs and speed sensor abs faults as they were already there and are on my list of things to do, but as you can imagine this new fault is a priority as its going to be dangerous without a horn, indicators or wipers working.
Thanks in advance
Ben
00-Steering Angle Sensor -- Status: Sporadic communication error 1000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Cannot be reached 1100
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Revision: 00T12001
Coding: 0023170
Shop #: WSC 06314 000 00000
VCID: 408FA68B1376181ED43-8015
3 Faults Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
003 - Mechanical Failure - Intermittent
00778 - Steering Angle Sensor (G85)
000 - -
004 - No Signal/Communication
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 K HW: 8P0 820 043 K
Component: KlimavollautomatH17 0200
Revision: 031274 Serial number: 8P0820043K
VCID: 3467FA5B57CEB4BE40B-8061
3 Faults Found:
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 150
Mileage: 284945 km
Time Indication: 0
Date: 2015.08.13
Time: 19:04:23
Freeze Frame:
Temperature: 19.5°C
Voltage: 12.10 V
RPM: 12750 /min
Load: 0.0 %
Load: 0.0 %
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 150
Mileage: 284945 km
Time Indication: 0
Date: 2015.08.13
Time: 19:04:30
Freeze Frame:
Temperature: 60.0°C
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 123
Mileage: 285171 km
Time Indication: 0
Date: 2015.08.20
Time: 10:13:04
Freeze Frame:
ON
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H36 1201
Revision: 00H36000 Serial number: 00000002099242
Coding: A1884F00B214100000000000300000000008FE175C1100
Shop #: WSC 06314 123 08192
Subsystem 1 - Part No: 8P2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
10 Faults Found:
00188 - Control Circuit 1; Relay for Supply Voltage Terminal 50
Freeze Frame:
Fault Priority: 1
Fault Frequency: 5
Reset counter: 158
Mileage: 284945 km
Time Indication: 0
Date: 2015.08.13
Time: 19:05:00
Freeze Frame:
OFF
Voltage: 11.85 V
OFF
ON
OFF
OFF
OFF
00187 - Control Circuit; Relay for Supply Voltage Terminal 75X
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 158
Mileage: 284945 km
Time Indication: 0
Date: 2015.08.13
Time: 19:05:00
Freeze Frame:
OFF
Voltage: 11.85 V
OFF
ON
OFF
OFF
OFF
00156 - Control Circuit for Windshield Washer Pump
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 158
Mileage: 284743 km
Time Indication: 0
Date: 2015.08.08
Time: 08:04:00
Freeze Frame:
ON
Voltage: 11.95 V
OFF
ON
OFF
OFF
OFF
02398 - Control Circuit for Rear Windshield Washer Pump
Freeze Frame:
Fault Status: 00111001
Fault Priority: 3
Fault Frequency: 2
Reset counter: 158
Mileage: 284743 km
Time Indication: 0
Date: 2015.08.08
Time: 08:04:00
Freeze Frame:
ON
Voltage: 11.95 V
OFF
ON
OFF
OFF
OFF
01800 - Light Switch (E1)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 158
Mileage: 284945 km
Time Indication: 0
Date: 2015.08.13
Time: 18:55:00
Freeze Frame:
OFF
Voltage: 11.95 V
OFF
ON
OFF
OFF
OFF
02401 - Terminal 75x
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 158
Mileage: 284743 km
Time Indication: 0
Date: 2015.08.08
Time: 08:04:00
Freeze Frame:
ON
Voltage: 11.95 V
OFF
ON
OFF
OFF
OFF
01321 - Control Module for Airbags (J234)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 150
Mileage: 284945 km
Time Indication: 0
Date: 2015.08.13
Time: 19:04:00
Freeze Frame:
ON
Voltage: 11.95 V
OFF
ON
OFF
OFF
OFF
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 150
Mileage: 284945 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.95 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 123
Mileage: 285171 km
Time Indication: 0
Date: 2015.08.20
Time: 10:11:00
Freeze Frame:
OFF
Voltage: 11.95 V
OFF
ON
OFF
OFF
OFF
01309 - Power Steering Control Module (J500)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 150
Mileage: 284945 km
Time Indication: 0
Date: 2015.08.13
Time: 19:04:00
Freeze Frame:
ON
Voltage: 11.95 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 00362003W4X/
Coding: 0074622
VCID: 428BAC831D7A0A0EC27-8017
Subsystem 1 - Serial number: 6332DRB401FA949E2
Subsystem 2 - Serial number: 6342DRB401FA852AZ
Subsystem 3 - Serial number: 63528RB4007E6580K
Subsystem 4 - Serial number: 63628RB400837629G
Subsystem 5 - Serial number: 63729RB40093E2B8U
Subsystem 6 - Serial number: 63829RB40093E416L
No fault code found.
Address 16: Steering wheel
Cannot be reached
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 981 B HW: 8P0 920 981 B
Component: KOMBIINSTR. VDO H80 0410
Revision: D03 Serial number: 2246ED03002835
Coding: 0004443
Shop #: WSC 08447 016 82372
VCID: 377DCD5746B85FA6659-8062
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001057158902
Coding: 3D3F0B42072103
VCID: 2A5BE423850AF24EEA7-807F
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 123
Mileage: 285171 km
Time Indication: 0
Date: 2015.08.20
Time: 10:11:42
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 163
Mileage: 285171 km
Time Indication: 0
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D03 Serial number: AUX7Z0E6FNP031
Shop #: WSC 06402 145 00197
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
Part No: 8P0 959 801 H
Component: Tuer-SG 020 0070
Coding: 0000688
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
Shop #: WSC 00000 000 00000
VCID: 3365F94752C0B386591-8066
1 Fault Found:
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 C
Component: KSG H04 0050
Coding: 198000186D088505489FC63300
VCID: 3C77D27B7F9E7CFE88B-8069
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H03 0020
1 Fault Found:
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 HW: 8P4 035 382
Component: AB2 SUBWOOFERBOXH04 0180
Revision: 00003 Serial number: 30209244232860
VCID: F1E9B34FE85C4196EBD-80A4
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Coding: 0000688
VCID: 4189A38F187C1116DBD-8014
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No: 8P4 959 801 D
Component: Tuer-SG 020 0060
Coding: 0000144
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No: 8P4 959 802 D
Coding: 0000144
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D51EF3FB4E4E5760F5-8078
End ---------------------------------------------------------------------
Thanks in advance
Ben
Address 01: Engine
Cannot be reached
Revision: 00T12001
Coding: 0023170
3 Faults Found:
000 - -
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 150
Mileage: 284945 km
Time Indication: 0
Date: 2015.08.13
Time: 19:04:23
Freeze Frame:
Temperature: 19.5°C
Voltage: 12.10 V
RPM: 12750 /min
Load: 0.0 %
Load: 0.0 %
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 150
Mileage: 284945 km
Time Indication: 0
Date: 2015.08.13
Time: 19:04:30
Freeze Frame:
Temperature: 60.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 123
Mileage: 285171 km
Time Indication: 0
Date: 2015.08.20
Time: 10:13:04
Freeze Frame:
ON
Coding: 00062736
Shop #: WSC 06314
10 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 5
Reset counter: 158
Mileage: 284945 km
Time Indication: 0
Date: 2015.08.13
Time: 19:05:00
Freeze Frame:
OFF
Voltage: 11.85 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 158
Mileage: 284945 km
Time Indication: 0
Date: 2015.08.13
Time: 19:05:00
Freeze Frame:
OFF
Voltage: 11.85 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 158
Mileage: 284743 km
Time Indication: 0
Date: 2015.08.08
Time: 08:04:00
Freeze Frame:
ON
Voltage: 11.95 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 158
Mileage: 284743 km
Time Indication: 0
Date: 2015.08.08
Time: 08:04:00
Freeze Frame:
ON
Voltage: 11.95 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 158
Mileage: 284945 km
Time Indication: 0
Date: 2015.08.13
Time: 18:55:00
Freeze Frame:
OFF
Voltage: 11.95 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 158
Mileage: 284743 km
Time Indication: 0
Date: 2015.08.08
Time: 08:04:00
Freeze Frame:
ON
Voltage: 11.95 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 150
Mileage: 284945 km
Time Indication: 0
Date: 2015.08.13
Time: 19:04:00
Freeze Frame:
ON
Voltage: 11.95 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 150
Mileage: 284945 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.95 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 123
Mileage: 285171 km
Time Indication: 0
Date: 2015.08.20
Time: 10:11:00
Freeze Frame:
OFF
Voltage: 11.95 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 150
Mileage: 284945 km
Time Indication: 0
Date: 2015.08.13
Time: 19:04:00
Freeze Frame:
ON
Voltage: 11.95 V
OFF
ON
OFF
OFF
OFF
Coding: 0074622
Cannot be reached
Coding: 0004443
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 123
Mileage: 285171 km
Time Indication: 0
Date: 2015.08.20
Time: 10:11:42
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 163
Mileage: 285171 km
Time Indication: 0
Coding: 0000688
1 Fault Found:
1 Fault Found:
Coding: 0000688
Address 56: Radio
Cannot be reached
Coding: 0000144
Coding: 0000144
