Help! Passenger's window won't close! VCDS Code.
SAiLO
Well-Known Member
UK
Hi guys,
Something happened and I can't close the passenger's window.
Got this error code through VCDS:
00933 - Electric Window Motor; Passenger Side (V148)
012 - Electrical Fault in Circuit
Did the testing - When trying to Lower/Raise the window I only hear a tick in the door but no movement of the window. VCDS says "inactive" with both test.
Thought it might be a fuse but it wouldn't make any sound then, am I correct?
Which fuse is responsible for the window motor on passenger's side
It might get unpleasant when it starts raining!
There's a 3inch gap and (touch wood) I hope no one will try to find their way inside.
I will try to take the door card off tomorrow, unless someone's got a solution.
Any help appreciated!
I'll try to look at it tomorrow, remove the door card and see what is the cause. Hopefully it won't be anything serious.
I've tried both switches and neither of them shut the window. As for the lock button, holding it does not close either sides.
