Help with fault code
mallygreen
Scottish Highlands
Hi, Im hoping someone can help me with this. I ran a scan on the car and it came up with this fault code-
Address 01: Engine (J623-CGLC) Labels: 03L-906-018-CGL.clb
Part No SW: 03L 906 018 JG HW: 03L 906 018 JL
Component: R4 2,0L EDC H25 2839
Revision: 45H25---
Coding: 12194012242401080000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM20TDI01103L906018JG 003005
ROD: EV_ECM20TDI01103L906018JG.rod
VCID: 78F99EBBC35199DEA3D-802D
1 Fault Found:
5120 - Oxygen (Lambda) Sensor B1 S1
P2196 00 [237] - Signal too High (Rich)
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 40
Mileage: 86972 km
Date: 2016.07.06
Time: 17:33:50
Does this mean the lambda sensor needs replaced or where it`s saying "signal too high (rich)" is that the actual fault and if so any ideas on how to fix it?.
Any help would be much appreciated.
Thanks Pete.
Hi,
Did you ever get answers to your question?
I have the same problem
Error
WSC 06325 000 00000
And
WSC 06324 000 00000
And
Revision: 45H25---
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 40
Mileage: 86972 km
Date: 2016.07.06
Time: 17:33:50
Thanks Pete.
Dug this out from the net which might help if you follow 1-6 .
HTC
3K
NHN
3K
NHN
