need help before i waste any money, got fault code P0102 mass air flow sensor signal too low.
i checked the pins with a multi meter and only got 4.9v on one of the pins but no 12v or any thing on any of the others.
i then checked with vcds and its showing no reading on the maf block 003, what could be wring? i did notice that one of the pins in the connecter block is loose think it might be the ground could this be the problom?
thanks guys
Neil
thanks guys
Neil
