GoldenArrow
- Joined
- Dec 11, 2010
- Messages
- 6
- Reaction score
- 0
- Points
- 1
Various Faults on A3 2.0tdi
HI all, new to the forum and owning an Audi.
I am hoping someone can help me out here with advice on whats wrong with my new car that I love apart from the following.
Recently purchased a 2004 A3 2.0tdi with some faults although I only thought she had fault one on purchasing.
1, The open door switches on the driver door is not working so not getting the headlight on alarm when getting out and no puddle lights or door open light (passengers is fine). I assume this is just a lock swap out or is it connected to another fault?
2, Now I assume that the 2 bottons on the driver door for the alarm sensors should light up when you press the buttons. Mine doesn't I dont know but possibly linked to the door lock micro switches?
3, The car has an ipod denison installed but the concert does not seem to see it as a cd changer even when pressing the cd button once or twice.
4, today whilst playing with the climate control it went off as in all the lights on it went out then they came back, also shortly afterwards the radio went off, came back on on second attempt at turning back on.
Before picking her up she had a dead battery which was replaced so dont know if any of the fault codes i got on vag com are related to that but hopefully someone looking at this will now what my problems all relate to.
Thanks in advance for any advice it will greatly appreciated as I want to enjoy driving my Audi even if its not a 2010 model.
VCDS Version: Release 908.0
Data version: 20090911
Saturday,11,December,2010,18:40:11:13314
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 7D
VIN: WAUZZZ8P Mileage: 142270km/88402miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 FF HW: 028 101 190 5
Component: R4 2,0L EDC 0000SG 6337
Revision: 12345678 Serial number: AUX7Z0D5FNE0CW
Coding: 0000072
Shop #: WSC 06435 000 00000
2 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 000 - - - Intermittent
Freeze Frame:
RPM: 1344 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.56 V
Bin. Bits: 11000100
Bin. Bits: 11000000
(no units): 1.0
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 000 - - - Intermittent
Freeze Frame:
RPM: 399 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.56 V
Bin. Bits: 11000100
Torque: 0.0 Nm
Torque: 346.0 Nm
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0023174
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 D HW: 8P0 820 043 D
Component: KlimavollautomatH12 0150
Revision: 061925 Serial number: 8P0820043D
Shop #: WSC 00000 000 00000
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 0 km
Time Indication: 0
Freeze Frame:
ON
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H30 0501
Revision: 00030000 Serial number: 00000000816553
Coding: 01884F00A2141000000000000000000000
Part No: 8P2 955 119 C
Component: Wischer WWS Audi350 0180
Coding: 16187408
Shop #: WSC 00000
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
Component: Airbag 8.4ED H00 0140
Coding: 0011602
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 012 0030
Coding: 0000012
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 980 P HW: 8P0 920 980 P
Component: KOMBIINSTR. VDO H71 0200
Revision: D01 Serial number: 2245DD01000727
Coding: 0004408
Shop #: WSC 00441 210 61830
1 Fault Found:
00562 - Sensor for Oil Level/Temperature (G266)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 00000011
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Mileage: 141256 km
Time Indication: 0
Date: 2010.11.09
Time: 23:38:03
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 25001045210110
Coding: 3D0F0B40070101
1 Fault Found:
00381 - Databus Instrument Cluster
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 1
Fault Frequency: 44
Reset counter: 245
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Revision: D01 Serial number: AUX7Z0D5FNE0CW
Shop #: WSC 00441 210 88110
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.lbl
Part No: 8P0 959 801 E
Component: Tuersteuerger. H10 0030
Coding: 0000048
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K2 909 144 G
Component: EPS_ZFLS Kl.10 1301
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H02 0040
Coding: 008000186D288505489AC63000
Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
Part No: 1K0 907 719
Component: Neigungssensor 003 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H03 0010
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.lbl
Part No: 8P0 959 802 E
Coding: 0000048
1 Fault Found:
00933 - Electric Window Motor; Passenger Side (V148)
Address 56: Radio
Cannot be reached
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 D HW: 1K0 963 235 D
Component: PTC-Element 0404
Revision: 00700000 Serial number:
End ---------------------------------------------------------------------
GoldenArrow
Chassis Type: 1K0
Coding: 0000072
2 Faults Found:
Freeze Frame:
RPM: 1344 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.56 V
Bin. Bits: 11000100
Bin. Bits: 11000000
(no units): 1.0
Freeze Frame:
RPM: 399 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.56 V
Bin. Bits: 11000100
Torque: 0.0 Nm
Torque: 346.0 Nm
Coding: 0023174
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 0 km
Time Indication: 0
Freeze Frame:
ON
Coding: 16187408
Shop #: WSC 00000
Coding: 0011602
Coding: 0000012
Coding: 0004408
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Mileage: 141256 km
Time Indication: 0
Date: 2010.11.09
Time: 23:38:03
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 44
Reset counter: 245
Coding: 0000048
1 Fault Found:
Coding: 0000048
1 Fault Found:
Address 56: Radio
Cannot be reached
GoldenArrow
