looking for advice and potential solutions to this. I shall give the back story too.
Bought the car off a mate (B5 RS4) and there wasn't an issue with any front end vibrations. The front brakes needed a refurb as the bells were corroded (its got a 370mm movit kit on the car)
So I have had the following done
New bells made to the same movit design
New bolts and bobbins to bolt the bells to the rotors
Rotors skimmed (including the mating face to the bells)
Calipers have been totally refurbished with new fluid and dust seals
Whilst the car was off the road I fitted a set of uprated front and rear anti roll bars too. Hotchkis front and 034 rear with subframe strengthening brackets.
I also changed the rear calipers as they were totally seized, I used a pair off my S6 as they are the same and known to be free and working.
The trouble im getting.
When the brakes are stone cold I get a light vibration.
When they have heat in them the vibration gets very bad, and under light braking with the hot brakes at 20-30mph its so bad it is undrivable almost, most of the vibration is though the steering wheel, very little if any through the pedal, I shakes the whole car and feels like im in 6th gear and about to stall (its not but that's how violent it gets)
I found if braking lightly at 20-30mph and turning the vibration lessens but is still very much there.
At higher speeds its bad again, more noticeable with light braking, stamping on the pedal its still very much there but not quite as bad.
The runout was checked and is 0.12mm on one side and 0.16mm on the other, I checked the runout on the hub faces and they are 0.01/0.02mm.
We thought it was the bells that were made out some monkey metal and deforming when hot, so I changed them back to the known good movit ones and its exactly the same.
Its also the same with old or new pads.
Someone suggested the new thicker front antiroll bar might highlight any bad bushes I have, so I disconnected the drop links and its still exactly them same.
Another thought would be air in the abs block as I had all 4 calipers off (although the rears were swapped immediately and the fronts were blocked off so not much fluid came out), also the fact the calipers have been refurbished maybe it wasn't done properly and not all 4 pistons are coming out as they should?
I don't mind spending money on the car, but im reluctant to do so unless I know its a cure, I did think of buying new discs and bells from movit but im not sure that's even the problem.
long post I know but I figured if you know what I do it should help with the ideas
cheers
cheers
