The only light you'd have if you don't have the Interior Light Pack is the overhead ones I think, just take the panel down and checked the bulb and use a multimeter to check power is getting there. Also check fuse.
I’ve got no lights working at all from the ceiling, both front and on the back.
when I took front covers off, there’s no sign of a bulb. Just a massive circuit board??
- seems that you have the premium dome light unit with the 2 independent maps lights. Did all the lights stop working at the same time? If so it seems much more likely that there is a supply problem, rather than all the bulbs failing simultaneously. Have you checked the fuse?
