How many exhaust gas temp sensor does 3.0 tdi got?
Kim Lerhaugen
Hi I wonder how many exhaust gas temp sensor my allroad 2017 204hp got?
Because only temp sensor 3 and 4 is moving in vcds, 1 is on 1000c and 2 is on 222c all the time.
Var is low on power.
desertstorm
Moderator
Staff member
Moderator
The modern diesels typically have 3 or 4 sensors. The lowest number sensor is closest to the engine. So 1 is pre turbo usually in the manifold collector, 2 is either post turbo pre cat/DPF or pre DPF , 3 is pre DPF or post DPF . You get the idea.
If the EGT sensors have failed the DPF regeneration will not be working correctly if at all.
If you look at item 5 in the diagram this is sensor 1 .
https://audi.7zap.com/en/rdw/audi+a6+avant/a6/2016-798/1/145-145045/
If you remove the engine cover and look at the back of the turbo you should see the sensor and wiring.
Is the car standard?
Kim Lerhaugen
IT is a 2014. I pushed wrong button.... IT is tuned stage one. Reason i ask is. I got the flashing glow sign and engine light. Low on power. Got this log i Will post SOON. I did a regeneration in vcds. Code is gone and lights in the dash is gone. But the car doesn't got the power.
Kim Lerhaugen
Fr1iday,08,January,2021,08:48:19:63590
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4513.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WAUZZZ4G7EN164992 License Plate: CV73097
Mileage: 144546km-89816mi Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 20 28 34 3B 3C 42 44
46 52 53 55 56 5F 62 69 6C 6D 72 85 8B 8E 8F 90
VIN: WAUZZZ4G7EN164992 Mileage: 144546km-89816miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
20-High Beam Assist. -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: OK 0000
8E-Image Processing -- Status: Malfunction 0010
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
Address 01: Engine (J623-CLAA) Labels:. 059-907-401-V2.clb
Part No SW: 4G0 907 311 E HW: 4G0 907 401
Component: 3.0TDI EDC17 X41 0003
Revision: 53X41---
Coding: 3225401A057609020000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TDI0114G0907311E 001003
ROD: EV_ECM30TDI0114G0907311E.rod
VCID: 2517F47C056E8043015-8070
2 Faults Found:
5188 - Diesel Particle Filter
P2463 00 [237] - Excessive Soot Accumulation
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 144546 km
Date: 2021.01.07
Time: 07:01:32
Engine speed: 1390.00 /min
Normed load value: 59.2 %
Vehicle speed: 31 km/h
Coolant temperature: 37 °C
Intake air temperature: -10 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.520 V
Unlearning counter according OBD: 40
P Flt Ld fac Ash Cor: 0.8950
Particul.filter diff.pressure: 18 hPa
Exh t Adap T Oxi Cat Ds: 184.9 °C
Exh t Adap TP Flt Ds: 188.5 °C
Exhaust gas jet volume in particle filter: 238.8 m³/h
Current operating mode_2-Bits 0-7: 0
Current operating mode_2-Bits 0-7: 16
5189 - Particulate Trap Bank 1
P2002 00 [109] - Efficiency Below Threshold
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 144546 km
Date: 2021.01.07
Time: 07:01:32
Ambient temperature: -12.0 °C
Particle filter: offset for differential press.: 1 hPa
Particle filter: soot mass measured: 0.21 g
Particle filter: soot mass calculated: 35.81 g
Particle filter: kilometers since last regeneration: 920688 m
Particle filter field regeneration: cancel conditions-Bits 0-7: 0
Readiness: 1 1 0 0 X
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 4G5 927 156 A HW: 0B5 927 156 K
Component: 0B5 30 TDIRdW H02 0003
Revision: --H02---
Coding: 000001
ASAM Dataset: EV_TCMDL501021 001015
ROD: EV_TCMDL501021.rod
VCID: 2F3B16545792CA13FB9-807A
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 M HW: 4G0 907 379 M
Component: ESP PREMIUM H09 0450
Revision: -------- Serial number: --------------
Coding: 27A6DF05E465FBA0EB00
ASAM Dataset: EV_ESPPremiAU57X 004039
ROD: EV_ESPPremiAU57X_004_AU57.rod
VCID: 3B23320493EA26B3471-806E
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 EN HW: 4H0 907 064 EN
Component: BCM2 2.0 H36 0521
Revision: 00002001
Coding: 01A93006000000000000
VCID: 79AFE80CD9D6D4A315D-802C
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 AM HW: 4G0 820 043 AM
Component: KLIMA 4 ZONEN H14 0096
Serial number: 14051400041115
Coding: 369200782D
ASAM Dataset: EV_AirCondiComfoUDS 004003
ROD: EV_AirCondiComfoUDS_004.rod
VCID: 6A8DC740ACF06F3BEC7-803E
1 Fault Found:
0386 - Functional Limitation due to Energy Management
B10CD 00 [009] - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 123
Mileage: 144546 km
Date: 2021.01.07
Time: 07:49:31
Voltage terminal 30: 11.13 V
Outside air temperature: -10.0 °C
Energy management deactivation stage: 1
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001876702
Coding: 0907E01009749FE28981008300001800CF9C67082E080201000108546F01
VCID: 6FBBD65497928A13BB9-803A
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 140506 H37 0080
Serial number: 140508061656
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 22889110
Coding: 02006C
Subsystem 3 - Part No SW: 4G0 941 531 S HW: 4G0 941 531 S
Component: E1 - LDS H07 0044
Serial number: 13 05 2014 00001873
Subsystem 4 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Serial number: 00000012051400010872
Coding: 110000
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Serial number: 00000017051400010574
Coding: 110000
Subsystem 6 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: D8780B27000000000001
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0083
Revision: 11001001 Serial number: 61061413202409
Coding: A9EB0C
ASAM Dataset: EV_EPHVA18AU57X0000 004009
ROD: EV_EPHVA18AU57X0000_004.rod
VCID: 71BFD02C81269CE3ADD-8024
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H19 0410
Serial number: 00000000000000
Coding: 7F04010202
ASAM Dataset: EV_AdaptCruisContrAU57X 002010
ROD: EV_AdaptCruisContrAU57X_002.rod
VCID: 2809FD48727C9D2B3A3-807C
Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG00HYS2X
Coding: 3032343631334E303437554A304C34473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
VCID: 36352330A8C8FBDBB8F-8062
Crash sensor for side airbag: driver side:
Serial number: 3575HRB40632FL64D0T6
Crash sensor for side airbag: front passenger side:
Serial number: 3585HRB40612FL649P1+
Crash sensor for side airbag: rear: driver side:
Serial number: 3515JRB40592LSO4AP3Y
Crash sensor for side airbag: rear: passenger side:
Serial number: 3525JRB400852JMSG28E
Crash sensor for front airbag: driver side:
Serial number: 3554VRB401852JMS4H9X
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB400G52K1O5181
1 Fault Found:
9572113 - Ignitor for Passenger Airbag Release Valve
B120F 11 [137] - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 144546 km
Date: 2021.01.07
Time: 07:48:36
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H04 0005
Revision: -------- Serial number: 90372NEC000KU
Coding: 0004FD
VCID: 38292D08A25C0DABAA3-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Component: E221 - MFL H08 0010
Serial number: 04 03 2014 B0239503
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G9 920 950 M HW: 4G9 920 950 M
Component: TDieRdwAccNv H58 0622
Revision: 29131237 Serial number: 658120514596014
Coding: 138621081F510008010600
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K_AU57.rod
VCID: 3A2D37009CD01FBB5C7-806E
Address 18: Aux. Heat (J364) Labels:. 8R0-265-105.clb
Part No SW: 4H0 265 105 G HW: 4H0 265 105 G
Component: Standheizung H24 0260
Revision: 66006006 Serial number: 20140301013525
Coding: 5D3F01
VCID: 2615F37078E88B5B08F-8072
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 4G0 907 468 AD HW: 4G0 907 468 AC
Component: J533--Gateway H13 0050
Revision: -------- Serial number: 00000001390112
Coding: 00CD077D00
ASAM Dataset: EV_GatewPkoUDS 001019
ROD: EV_GatewPkoUDS_001_AU57.rod
VCID: 72BDDF208420A7FB547-8026
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 3141123303
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 14022700000000000296
1 Fault Found:
12291 - Energy Management Active
U140B 00 [009] - -
[Powermanagement active]
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 123
Mileage: 144546 km
Date: 2021.01.07
Time: 07:49:14
Voltage terminal 30: 11.1 V
Voltage terminal 15: 11.1 V
Control Module temperature: -4 °C
System status: Terminal 15 on
IN ESP_standstill flag: standstill detected
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status via CAN: On
Terminal 15 status: On
Datenfeld: 16
Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 04018264747464545425363E00
VCID: 7CA1F118D6E4E18B0EB-8028
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 M HW: 4G0 919 158 M
Component: KLIMA FOND H08 0096
Serial number: 15051400040498
Coding: 21
ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
ROD: EV_ClimaContrUnitRearUDS_003.rod
VCID: 392F280C99D614A355D-806C
Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
Part No SW: 4G0 907 553 F HW: 4G0 907 553 F
Component: LUFE-DAEMPFER H18 0782
Coding: 008003
ASAM Dataset: EV_AirSuspe 003024
ROD: EV_AirSuspe_VW51.rod
VCID: 2E050B505098C31BF0F-807A
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H03 0056
Revision: -------- Serial number: EJ1BPA82078G0Z
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 E HW: 4G0 907 566
Component: J769 SWA MasterH04 0040
Revision: 00H04000 Serial number: 6PZ 010 287-04
Coding: 0010104
VCID: 313F102C4D26DCE3EDD-8064
Subsystem 1 - Part No: 4G0 907 568 E
Component: J770 SWA Slave H04 0040
Subsystem 2 - Serial number: 6PZ 010 287-24
Subsystem 3 - Serial number: 5F07.05.1400H04000AMS14063ÿ
Subsystem 4 - Serial number: S14063ÿ
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
Component: TSG FA H04 0507
Coding: 011F16005C00628002080013
VCID: 45D754FCE5AE6043215-8010
Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H40 0010
Revision: 00001000 Serial number: 0030543384
Coding: 101001010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 323D1F2044A0E7FB947-8066
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0335732269
Coding: 013A0620A0B93094832009042E010F470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 4G9 959 591 HW: 8V3 959 591
Component: J245 PS20.008 H02 0007
Serial number: WOO28367448
Coding: 901F00
Subsystem 4 - Part No SW: 4G9 959 591 HW: 8V3 959 591
Component: J394 PS20.008 H02 0007
Serial number: WOO2888983K
Coding: 801F00
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4G8 959 792 J HW: 4G8 959 792 G
Component: TSG BF H03 0507
Coding: 011F16005E00628002080002
VCID: 46D553F0D8A86B5B28F-8012
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H03 0015
Revision: -------- Serial number: 00000001063344
ASAM Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D070C5C5D9EB803C95-8078
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Component: ....LWR12.... H02 0010
Serial number: 140404-0002-116
Coding: 11226F601002A300
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic.rod
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 061 N HW: 4G0 035 061
Component: Radio U DAB H60 0139
Revision: AB001007 Serial number: 109E20E7927438
Coding: 010103020100000001
VCID: 2809FD4872FC9D2B3A3-807C
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 666 J HW: 4G0 035 666 H
Component: H-BN-EU H52 0798
Revision: -------- Serial number: 189E50E7582175
Coding: 080100050003FBEF3D90EB1E00000003E00001020200000000
VCID: 2F3B16545712CA13FB9-807A
Subsystem 1 - Part No: 8R0 060 884 BK
Component: EUR 2014 1703
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Serial number: AUZ8ZDED004K8EW
Subsystem 3 - Part No SW: 4G1 919 612 Q HW: 4G1 919 612 Q
Component: E380 BDT C7 H11 0204
Serial number: 90349NEF000HY
Subsystem 4 - Part No: 8R0 060 961 F
Component: CD-Database 5571
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4G8 959 795 J HW: 4G8 959 795 G
Component: TSG HL H03 0507
Coding: 010F14004000628002080002
VCID: 49CF58CCC9B68423C5D-801C
Address 69: Trailer (J345) Labels:. 4G8-907-383-V1.clb
Part No SW: 4G8 907 383 HW: 4G8 907 383
Component: Anhaenger H11 0100
Revision: 5G001001 Serial number: 00008200216291
Coding: 0109080000000000
VCID: 71BFD02C81A69CE3ADD-8024
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H08--- Serial number: 525 PA8J44G631
Coding: 1090005
VCID: 2615F37074E88B5B08F-8072
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G9 959 107 B HW: 4G9 959 107 A
Component: HDSG-Modul H03 0143
Revision: 14003001 Serial number: 129400130
Coding: 097205C011
ASAM Dataset: EV_HDSGAu572 001022
ROD: EV_HDSGAu571.rod
VCID: 3537243CB5CEF0C3B15-8060
1 Fault Found:
0114 - Load Space Cover
B12EF 54 [137] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 119
Mileage: 144288 km
Date: 2020.12.22
Time: 11:13:39
Voltage terminal 30: 11.91 V
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0507
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H26 0038
Revision: -------- Serial number: 262130025421000
Coding: EA060000
ASAM Dataset: EV_OnBoardCamerDPC 001007
ROD: EV_OnBoardCamerDPC.rod
VCID: 2615F37078688B5B08F-8072
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Component: ACC3 H19 0400
Coding: 7F04010202
ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
ROD: EV_AdaptCruisContr2AU57X_002.rod
Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
Part No SW: 4G0 907 107 E HW: 4H0 907 107
Component: BV-SG H32 0041
Serial number: 005000121205147
Coding: 04C0BA1C1111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
1 Fault Found:
0049 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[Airbag_Airbag_01_System_error]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 123
Mileage: 144546 km
Date: 2021.01.07
Time: 07:48:36
Voltage terminal 15: 11.0 V
Control Module temperature: -9.0 °C
Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H13 0080
Coding: 0066E608031F0376070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L_VW51.rod
VCID: 313F102C41A6DCE3EDD-8064
Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R_VW51.rod
End----(Elapsed Time: 02:44, VBatt start/end: 11.4V/11.4V. VIgn 11.4V)-----
desertstorm
Moderator
Staff member
Moderator
From the VCDS logs
So it's done 920 Km since the last regen and the soot level is high. The DPF is blocked.
It's possible the readings you are seeing for the EGT sensors is a result of the remap, that's why I asked. Poor tunes on diesels sometimes ignore the EGT readings or recalibrate the sensors as they will protect the engine so potentially reduce the maximum amount of power made.
Who did the remap and how long ago??.
Kim Lerhaugen
The Company Who did the remap is a well known Company in Norway ES tuning. IT was done 1,5 years ago. Gess 15.000km ago. So IT gave done lots of regeneration sin e that time?
Kim Lerhaugen
Som Reading after regeneration
