According to Bryan's report, your average paint readings were around 110 microns with hgiher readings around resprayed parts. Using a PC with say Menzerna Intensive Polish 3.02 on a polishing pad slowly over an area will remove about 1 micron, maybe 2! So I would say that you have quite a few PC sessions still to go! No danger. You probably would not need to use say Power Gloss (heavy compound) with the PC as it's not great breaking it down, although I have spent ages on the PC with it. Now you've had you car detailed, IP should be all you have to use in future, at the most.
Personally, I'll machine the fine swirling on my own car about once a year in springtime, maybe twice a year at a push. Like your, mine has been done, and I should only really need to use Final Finish Menzerna (106FA) on a polishing pad.
The real issue is the thickness of the clearcoat when machine polishing, and not the total thickness of primer, paint and clearcoat combined. So, a total reading of 110 that Bryan got would allow you to make a judgement as to what machine/pad/polish combo to use. There are more expensive gauges out there (approx £1600 upwards) that might be give a clue to how thick the actual clearcoat is. But even then, it is not 100% exact due to the dubious boundary that the paint and clearcoat happen to combine to make! So, again it helps judgement and is not to be taken as gospel. For example if it shows a thin reading, say 60 microns, on bumpers then it could mean the paint AND clearcoat is 60 microns so a pro might go with the PC rather than the rotary.
I hope this is okay but basically it should be no probs using the PC a good few times! And, taking your time you will get good results with it, particularly now you've got a healthy fresh layer after Bryan's work.
Get yourself a basic paint gauge, Eshrules is running a group order on DW for £130. Worth getting one. When you get around 95 microns left, then get advice or sell the car!!!!!
Richard may probably want to add the pro's perspective on this one.
Hope this helps,
JOHN:icon_thumright:
