how to replace front badge on A3 2021
Hi how do i go about getting a new black badge for the a3 2021 but not from audi themselves? all ive seen availible are too long, ive look into getting to the clips from behind the grill by removing the cover between the front and engine bay, i can get my hand down there and touch the grill area but not sure what it looks like down there, i was hoping to push the clips out from behind, has anyone done this? thanks
wow ive been looking everywhere for one thats 249mm ish thats what my front one is, all ive seen is the 270mm thansk ill look into it, did you get one from here? does it fit well? i was hoping to pop it out from theback of the grill as the grill surround is quite tight against the badge :/ im more bothered about bending out the grill around the badge than the badge itself, thanks for the help.
bfevo
I ordered one today from the same place, you wont bend it just make sure you use the right tools. Slip a cable tie in once you have one corner off so you get my leverage and can pull as well as pry
ive ordered one so ill give it ago when it comes, i dont have a pry tool all i have are flat blade screwdrivers :p do you have a link to what you would be using? thanks
Frizzley
Frizzley
