Hello all, I've done my best to finalize this build myself; but I'll probably benefit from having someone else check it over.
A few things to note: My goal is 325-350hp. I have a BAM engine. The car is LHD. 125,000 kilometres or 78,000 miles on the odometer. Timing belt and water pump changed this spring.
Engine Internals:
Forged, rifle-drilled rods (IE)
Exhaust valves, triple groove, iconel (Supertech)
Intake valves, triple groove (Supertech)
Valvetrain kit; springs, retainers, spring seats (Supertech)
Main bearings, calico coated (ACL)
Rod bearings, calico coated (IE)
Piston rings (OE)
Crank damper bolt (ARP)
Main stud kit (ARP)
Headbolts (OE)
-Gaskets will be supplied by the mechanic.
-Piston walls will be lightly honed/deglazed.
-Do I need bolts for crank damper pulley to timing gear?
Engine Performance:
K04-380 (AET)
Exhaust manifold (Turbo Concepts)
Fuel injectors, 550cc (Bosch)
FMIC (Wagner)
80mm TIP (Turbo Concepts)
Cone filter (Jetex)
Coilpack upgrade (Audi R8)
Fuel pump (DW65)
Oil pump (OE)
-what hoses and or pipes should I replace?
Exhaust:
3" downpipe w/ 200 cell sport cat (CTS Turbo)
Downpipe installation kit; studs, nuts, gasket (ECS)
2.75" non-resonated catback (Milltek)
-How does the downpipe connect to the Milltek catback?
Brakes:
4 Piston front calipers w/ 330mm discs (Porsche)
Rear brake kit OE calipers w/ 306mm discs (ECS)
-Brake pads and fluid are TBD.
Suspension and more:
Dampers (Bilstein B8)
Springs; 25mm lowering (H&R)
Adjustable rear tie bars (Forge)
Spacers; 15mm rear, 10mm front (H&R)
ARBs; 25mm front, 21mm rear (H&R)
All new bushings (Powerflex; except front wishbone rear bushings: OE)
The exhaust manifold and TIP are from a German site that I kind of took a chance on: https://www.turbo-concepts.de/ (I use google chrome to translate it).
I know I'll probably need a WMI kit for the power I want (325-350hp), is it most sensible to install it with everything else?
Thank you for reading.
Engine Internals:
Piston rings (OE)
Main stud kit (ARP)
Headbolts (OE)
Engine Performance:
K04-380 (AET)
FMIC (Wagner)
Cone filter (Jetex)
Fuel pump (DW65)
Oil pump (OE)
Exhaust:
Brakes:
