Hi Guys,
Bought a lovely A3 2.0 Tdi (BKD engine) recently and had an issue with the central locking not working on any door other than the drivers door, but discovered it was the wiring loom where the drivers door meets the A-pillar - a couple of wires were cracked.
Anyway, since I bought the car I have noticed a very small amount of white smoke on start up, hardly anything. I have also been keeping an eye on the coolant as I know these are famous for it disappearing. It has used about 15mm (looking at the header tank), causing it to dip just below the minimum fill line and yesterday I took the oil cap off to check for mayo...there was none, but there was quite a bit of white smoke coming out of the oil cap hole. Armed with these warning signs I had a look at the coolant - there were no bubbles in the coolant at idle, but give it some revs and some tiny bubbles started appearing.
So it seems obvious there is a small amount of coolant getting into the oil...which I think i'm right in saying could possibly be from a leak in the Oil Cooler, EGR Cooler or the dreaded Cylinder Head!
I am going to whip off the Oil Cooler and EGR Cooler and pressure test them and cross my fingers it might be one of these. Failing that it might be new Cylinder Head time, as I plan on keeping the car for a few years.
If anyone can give me any extra info or things to test that would be awesome.
Also info on where the Oil Cooler and EGR Cooler are actually located in the engine bay would be great, I'm guessing the Oil Cooler is near the Oil Filter? and I think I read the EGR Cooler is on the back of the engine so it's a get the car in the air jobbie?
Is the Cylinder Head difficult to change? I am pretty handy with a spanner, changed an engine and gearbox before so not scared of doing big jobs, just wondering how difficult to do it will be on the BKD and how many hours/days it will probably take.
Also I have read the AMC heads are better quality that the OE Audi ones, anyone had any experience with changing the head for either an AMC or OE refurbished?
Thanks in advance!
Thanks in advance!
