K03 Hybrid Failure.....Solved!
Dan_Avant
South West
I decided to take my stock and hybrid K03’s apart today and it’s clear to see why the hybrid failed.
First off, the inlet housing on the hybrid turbo had split:
26A1488F E1CE 4D38 ADA4 C4FCA38D7DED
Secondly, seal on the hybrid is horribly misshapen (red one is from the hybrid, which was on my car for a few thousand miles, the black one is the stock seal which was on the car for around 120k miles!!!):
09966455 1B12 4AC4 869B 4062971ACBBB
Here’s a pic of the compressor housings. Smaller one is from the stock K03, larger one was machined out to fit the larger compressor:
5E934AF4 438B 4FFF BECD F3F85386DEB7
Here’s a pic of the compressor wheels for comparison. Black one is stock K03, billet one is the hybrid (I didn’t have time to remove them from the turbos as it started peeing down!!!):
BC1AAE29 78F4 45E3 ABE0 4F924371C31A
C13B0855 8522 4EBC AEC8 438CB3AE67B1
0696311E A7C7 4962 A4BD EFF091218B21
I’m going to keep the hybrid compressor with a view to put it in the CTS K04 I have on the car now, eventually.
Interestingly, the hot side is slightly different on each of the turbos. The stock K03 has a small ‘lip’ next to the turbine where as the hybrid doesn’t (1st pic is the stock turbo
91B5F81B E9EF 4082 AD16 A41BBB89E929
779A96F0 09E2 4470 9DAF 3691E38DF1A0
Reactions: Charlie Farley
Once I’ve taken the compressors off I’ll take a pic of them side by side. The size difference is quite considerable!
Do you think the housing failure on the hybrid was a result of the enlargment process Dan?
The seal failure maybe in part a consequence of the housing failing etc.
Yeah it has to be, there’s nothing else that could cause the housing to split like that.
Im hoping as the CTS I have on the car now is a K04 the hybrid compressor will drop straight in without having to machine the housing?
Hi there I have. A a3 1.8 turbo sport and I’m having trouble when in higher end of boost towards top end only in 3rd too 5th revsdoes any one have this problem or can any one help solve this please regard dean
You need to run a diagnostic on the car to look for fault codes. Always the best place to start
Reactions: D34n6681
I have mate no fault codes part Fromm p0010 I think and that was cam position sensor so kept putting in low limp mode and p1269 I think which is cooling problem I have changed the thermostat and car never has over heated but my temp does not go up above the 60 on temp gauge any assistance b helpful changed cam position sensor 125 pound later sorted that but occasionally it still does it till turn if and on then little pocket rocket again but this can not b right so I need to sort this b4 start the stage 2 fit up and dyno thank you
707
3K
NOZ
