LED number plate light kit
bleedout
Sorry for the slight hi-jack but when fitting the above copper plates the bulb has to contact does anyone else seem to have a nightmare trying to get theres to touch / Work.
Both of mine are currently not working and despite a good bit fiddeling with them last night i cant get them to light up.
am i missing a trick or something here?.
got a multimeter so over the weekend i can check there is def voltage traveling over the contacts.
bleedout
yeah reversed them both and no luck after that.
they were working (with intermitant error on DIS) but now can get power through them at all.
bleedout
really hope not, guess multimeter in the morning will anwser that. ( heres hopeing)
fingers crossed my lights arrive in the post tomorrow as well.
Greeny233
It's all about the V8.
AUDI Rear Number Plate Light Lamps XENON WHITE LED UNIT No Canbus Error 6000K | eBay
Looks the business
Has anyone on here installed this kit?
They are quite expensive are they worth it?
Also the screws that hold on the number plate lights are well rounded on my car :(
Does anyone know the name or size or even better a link to the allen socket head bolts that can be used hold on the number plate lights?
I have these fitted in my Avant and they fit, look and work a treat. On the screw bit I would like to know the answer too as I want to replace mine.
AudidriverA4
Thanks greeny :thumbsup:
Any chance you could put up a pic of what they are like at night time?
do they light up the ground around them as well?
PauliM
Looks the business
I have the exact same kit fitted to my A3 worked first time no messing around just unscrewed the other bulb holder pushed this one in. Screwed it back up and worked first time :)
BRILLO
I have this kit also been on car over a year with no problems. Really bright and look really good.
Greeny233
They do light up the floor, almost usable as reversing lights at night, lol and if you open the boot with the lights on make sure you are wearing sun glasses :eek:D
and by day
bleedout
Greeny have you got Full DIS and if so do you get the annoying bulb out warnings?.
If not have you fitted resistors or do these just work without errors?.
Greeny233
I have full DIS and I get no warnings at all from them. For me the hardest job was getting to the awkward little screws, pretty much fit and forget.
bleedout
Sweet, just what i was hopeing to hear.
fingers crossed i get mine working tonight if the rain will just f***-off for a bit.
**EDIT**
Just fitted mine and can confirm these do infact work on cars with full DIS and do NOT throw up any errors.
Will confirm through that if you leave your sidelights on and try open the boot prepare to be blinded.
