Essexmiles
Hi,
I have a 140 A3 TDI 56 plate and yesterday the oil light poped up so pulled over and topped it up and thought nothing of it as I know these cars can burn a little oil (or so I'm told). Misses goes to use car this morning and low coolant light comes on straight away so got her to top it up a little. But now I'm worried there could be an issue with head gasket or turbo seals (these turbos water cooled and oil cooled like the mk4s?)
Only had the car since November and done about 4k init and oil level was fine (if I remember correctly it was between min and max) then but don't no about coolant but any coolant lose is a worry.
would these be linked or just a coincidence that the cars burned a bit of oil and come to the min point the same time as a coolant leak has sprung.
Car has done 100k miles now and just wondered if there's any check or tests I can do myself to rule out possible faults or if there's any common leak points like oil cooler ect. Misses is at work with the car at the moment so can't give it a look over till she's back. also oil was fine in filler cap and dipstick, no May ect
cheers
cheers
