LOWERING SPRING AUDI A4 DTM
hon
Looking for some lowering spring for a A4 dtm, does any company make lowering spring for this model?
Or is it the same as the s-line one? im looking about 40m drop, any idea which is a good one to go for?
As long as they are for the B7 (8E) it should be ok only other thing is to check if they suitable for the quattro. With regards to the 40mm drop the sline and dtm come lowered by 20mm so say the springs claim to lower by 40mm you need to subtract 20mm from that value so your overalll drop will be 20mm.
I believe there is a German seller on ebay doing some good deals on Eibach springs if you do a search some fellow members have gone down this route.
Struggling to find some good springs that will give 40mm drop over standard ride height, been looking at eibach, but they only do the pro kit and not the sportline for mine, and pro kit only give 30mm drop over standard height so wont notices any different on my dtm as its already lowered by 20mm standard.
Anyone got some suggestions for good springs to go for? thanks
If you can get them, H&R springs are very good or weitec do a 50mm kit which i have and its definately enough, failing that go with coilovers and you can have it sit however you want.
Get suspension for a 2.0tfsi quattro, the dtm is no different.
Thanks for the info, what is the ride comfort on the weitec? are they as good as eibach? and is H&R any good?
H&R are fantastic, iv heard good things about eibach but not had them on my A4, i had them on an 04 fiesta years ago and they were very harsh, had them on an 05 Impreza and they were perfect.
Weitecs are very good, cant complain, i have 50mm weitecs with 19"s and ET30 and was rubbing abit in rear untill i stretched tyres so there pretty low.
