Car has not been running so great since i got it back from Narco tuning last year after a dpf/egr delete and tune, had problems with white smoking at all temps. They recomended i blank out the egr with blanking plates which had been coded out and has now been done by Bobby.
Have had fumes in the cabin which got worse if I had the heaters on, so all winter been running with the heating off and opening the windows in intervals to clear out the fumes, this is simply because the white smoke was finding its way in through the vents in slow/stationary traffic.. yuck..
Exhaust had a little leak in the centre silencer which was easily fixed with a new clamp, but the fumes and cloud of white on idle was still pretty big issue, reversing into the smoke stinks the car out immediately.
Also power delivery was poor, seemed to have no extra pull from stock, just made a load of noise when foot went down but no proper acceleration for all the work that was done.
So any way, I saved up and took it to Bobby Singh on here for a new custom tune and general health check to hopefully fix the smoking and power.
And he seems to have cracked it (so far only had it back a few days)
He found the lambda sensor was broken, but the previous tuners had mapped out the error codes so that it was not reported on scans.. no idea why they did this. so new bosche Lambda sensor is now in and working correctly
He noted on the logging runs that it was running standard boost (1.5) and stock limits still in place, he also kindly noted it was slow lol
on closer inspection tables for mid boost (2000rpm) was at 1.7bar, but the rest for higher rpm was still standard 1.5 explaining why the loggin run showed standard stock values.
So Bobby has put in some blanking plates for the EGR, done a careful stage 2 map not pushing too much torque so my 122k clutch can have some more life, egts quoting 850 in third, replaced the lambda, and advised I need to change the thermostats (egr and rad) as my temp doesnt regulate at 90c, usually running a little cold.
Picked it back up and am a happy girl, second and third really tear up the tyres, so much more torque, can spin through all of second now so prob want to keep and eye on the tyres, the car generally feel much better and finally has some livelyness, and most gratefully, i am not seeing any white smoke belowing out the back any more and enjoyed driving home with my heating on the whole time
Waiting for a space on the rolling road for a saturday to get some figures.
