Marmite.......
JamesS4cab
It seems that i have started a bit of a collection of 19's and now have 3 sets. Most recent acquisition was a set of newly refurbished genuine Audi speedline splits which had been done in black. As i already have a set of black wheels i thought i would have a go at some wheel repainting! I know the result is a bit marmite, but it's hardly cost me anything and i think i have now perfected my spraying technique and i like the results.
So the story.........
Which to choose:
Then to split them down which caused me great pain as i forgot i had the M8 spline drive set in the tool box but took me 24 hours to suss this out.....
Bit of 120 grit to get rid of the laquer and there's no turning back......
First coat of primer and its all looking ok.....
Two coats of primer and i can't wait to see what it looks like:
3 coats of gloss white and when its dry, i can set it in situ:
Next to see if i like it enough to start the other 3 wheels:
Yep!
Centre caps all done, bolts painted black, and Audi logo's painted black. First rim back together:
All done - 2 coats of primer, 3 white, and 3 laquer.....
Now going to leave them for a week for the laquer to go off!
Not 100% perfect but i did it all myself with a rattle can in the garage so wasnt expecting it to be immaculate, but all in all, I am very pleased!
NHN
Site Sponsor
MTM's everyday of the week, white wheels on ibis car look strange, needs contrast James :)
A3Kent
I agree, those MTM's are lovely. Put them on.
Good job though!
JamesS4cab
Thanks for the comments!
I dont like the diamond cut MTM's on white cars either though. If i don't sell them, they will be going anthracite me thinks. I went for the black rim and black bolts detail to give me the contrast. I will let you know if it works on Saturday morning when i have wasted £52.80 on getting the tyres swapped over!
One more set of 19's and i can have a different one on each corner........... Now THAT is class. :arco:
PaulAr
S3 (8P)
Nutella
dubdemand
VAG Addict
Why do you have one white bolt? I perosonally quite like them and think they will look ok on your car but... the black lips will make the tyre profile seem larger and the alloy smaller. Why not paint the barrels a metallic grey or something to create a bit of contrast between the tyre and the rim?
S3Alex
Rarely neutral
Gold Supporter
Thanks for the comments!I dont like the diamond cut MTM's on white cars either though. If i don't sell them, they will be going anthracite me thinks. I went for the black rim and black bolts detail to give me the contrast. I will let you know if it works on Saturday morning when i have wasted £52.80 on getting the tyres swapped over!One more set of 19's and i can have a different one on each corner........... Now THAT is class. :arco:
Or a set of Fatso Gumballo tyres on each corner....
JamesS4cab
The white bolt was the one bolt in the entire set that was too badly damaged to remove! Good attention to detail skills!
I agree with the comment about making the tyre profile look large - its something that i have been considering. I do fancy them machine polished but the quotes i have been getting are ridiculous to machine polish (£300+!). Also been toying with the idea of spraying them some kind of silver but havent got round to it yet.
phil76
I like the cross wires in white mate they look well,keep them
and sell me the MTM's for £15 each ?
Zak0123
+1. Looking sweet though bud, good spray job!
Cozza McA
Crunching The Gears
Yep!
I think these look amazing!!
Wish i had the balls to do that to mine haha
chris.vincent3
Own a BMW now, HOWEVER I still own VCDS!
I must admit they look stunning, however once they have tyres on the black outer rim will make the alloy look smaller, and the tyres bigger :-/
PaulAr
S3 (8P)
What about a chrome effect powder coat or hyper silver outer with anthracite/metallic grey middle piece.
Then sell the MTMs and spend the money on booze and tabs.
RedDejavu
i thnik MTMs are one of the best looking alloys to fit 8p platform atm
JamesS4cab
I thought about the antracite option but given the fact that the MTM's were going to be anthracite, and i wanted to escape the norm, I decided to have a WTF moment and see what happens! If they look guff, then i will dip them and do something else! £30 and a few hours down the drain.
gogz s3
Full respect to you for having the guts to do that, but as said it has to be the mtm's
JamesS4cab
Lets not forget I have a set of black 19" BBS CH which look the absolute (if not a little overdone these days) mutts nuts IMHO........
Everyone says go with the MTMs but surely not in diamond cut silver???
qwagon
Really like the look of them. I think that the black rim making the wheel look smaller will work in your favour as sometimes 19s can look a tad large on a 8P
zaf786
whether you put em on or not they look mint mate if you decide to get rid of the speedlines one day let me know :)
JamesS4cab
Thanks Alex.
And just to appease dubdemand......... I just painted the last white bolt black!!
rOb_A
hi james, get the MTM's done in anthracite with the MTM log's put in white, they'll look :wub:
then we can start to talk about a swap for my oem rotors (maybe :blush:)
JamesS4cab
It appears that I am reasonably handy at wheel refurbishment myself so give me a few wheels and we can talk. ;0)
Forbzeeee
Well-Known Member
Well done James!! Looks like you have done a really good job there. Keep up the good work mate.
S.
Save the manuals
i like them all. put the wheels like that on the car, if you don't like put the mtms. after all they are all sitting in your garage!
Shadowman
You could overcome the 'big tyre' illusion by painting a thin white pinstripe on the outer edge of the black section of the rim, nearest the tyre.....not sure what it would look like, but why not put a thin pinstripe tape piece on one wheel to see first, so no current paintwork is damaged and you can see the effect ?
Might work............
dubdemand
VAG Addict
Smiffi
Paint the MTMs white and then send then to me. Loving white on white!
Good job by the way, you've got skills!
phil76
Well if you get addicted to heroin/crytstal meth or bubble in the future that offer will still stand to help fund you habit
lovely mate top job
JamesS4cab
Thanks guys - definately fitting them Saturday am and standing by my conviction that white on white will look the mutts. If i wanted to be conventional, i could fit one of the 2 sets of S3 18's or stick with the 19" CH's!!
Pictures to follow..........
JamesS4cab
Well to everyone that said that they would look ****e, you are 100% correct. Fitted one this morning and it looks total guff so took it off again and will split them down again later.
Pretty f'd off but **** happens and I know they can be rectified. Watch this space.........
S3Alex
Rarely neutral
Gold Supporter
Well to everyone that said that they would look ****e, you are 100% correct. Fitted one this morning and it looks total guff so took it off again and will split them down again later. Pretty f'd off but **** happens and I know they can be rectified. Watch this space.........
Shame to hear that!....
JamesS4cab
Nope. Think s3 on 17's with a 60 profile tyre......... Guff.
