P.s. Dane - You spelt official wrong in your sig
GOOD spot dude, that's been there for ages, and no-one has noticed!!
That said there shouldn't be any reason why the N75 can't be mapped
I'd rather it be that to be fair, it makes part throttle driving much nicer.
I am also considering putting a kill switch in for the N75 to run actuator pressure...
I have an idea for that... use an N249... its what it does (switching valve) and means you won't have it throwing fault codes etc all the time when the N75 is electrically disconnected
Yeah, maybe long term. We discussed this before. But short term, a kill switch will do... lol. That way I might get better than 0.0 MPG on my Facebook... lol.
Maybe a brick under the accelerator maybe more suitable? ;P
And where would be the fun in that?!?
Welly, I have to say that your are MAD! 400+ bhp and standard braking system!!
To be fair on a stock 225 you have to be mad to use standard brakes
that's very strange Wellyboots.....
It's not something stupid like the wastegate being forced open against the actuator is it? No amount of pre tension will stop that from happening if it's a weak spring.
perhaps time for a brave dyno run with the WG jammed fully shut? to see if it's a compressor issue or a WG issue?
good news! nice one bud Im sure you'll figure it out.
does it get to 22 psi and stay there, or get to 22 psi and then drop off?
Hard to say, but looks to me like it's dropping off, but only really slightly.
Here is a log excerpt:
RPM Boost (Mbar -1000)
3440 1320
3800 1480
4240 1730
4760 2130
5560 2450
6360 2480
6960 2460
7240 2470
Well that's not dropping off! It's climbing through the rev range, lovely.
It does tail a tad, but only a tiny tiny bit.
Peak boost there was at 6360, but it is pretty stable - almost like the actuator is allowing some gas to bypass the turbine and keeping a steady boost....
I'd be happy with that considering you've just had to bolt it on. Imagine it's potential though
yeah its not like its getting to 22 psi and the penny valve is opening and letting all the boost out.
A stiffer spring is a good plan
ps only 280 g/s pah :thumbsup:
you know you wanna be in the 300 club lol
Dyno.....
So what was going on with the boost in the end?
