Mil on
Danph
Southport
Hi, My audi 2008 Audi s5 is throwing up some codes, just curious if anyone can shed some light. ive tried swapping the cmp sensors from bank 2 to bank one and tested the 4 actuators its also just been carbon cleaned. i looked in the measuring blocks side of vagcom and noticed that bank 1 cam is adjusting by about half a KW but bank 2 cam just doesnt move.
3 Faults Found
001431 - Thermostat for Mapped Engine Cooling (F265): Open Circuit
P0597 - 004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Mileage: 197088 km
Time Indication: 0
Date: 2021.07.14
Time: 18:33:46
Freeze Frame:
RPM: 604 /min
Load: 34.1 %
Speed: 0.0 km/h
Temperature: 60.0°C
Temperature: 36.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 13.843 V
000024 - Bank 2: CMP Sens 2 (G163) / Engine Speed Sensor (G28): Incorrect Correlation
P0018 - 001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 1
Mileage: 197088 km
Time Indication: 0
Date: 2021.07.14
Time: 18:33:55
Freeze Frame:
RPM: 632 /min
Load: 29.4 %
Speed: 0.0 km/h
Temperature: 61.0°C
Temperature: 36.0°C
Voltage: 14.097 V
000025 - Bank 2: CMP Sens 4 (G301) / Engine Speed Sensor (G28): Incorrect Correlation
P0019 - 001 - Upper Limit Exceeded
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 197088 km
Time Indication: 0
Date: 2021.07.14
Time: 18:33:55
Freeze Frame:
RPM: 632 /min
Load: 29.4 %
Speed: 0.0 km/h
Temperature: 61.0°C
Temperature: 36.0°C
Voltage: 14.097 V
Readiness: 0110 1001
also some measuring blocks:
Address 01: Engine (8T0 907 560 F)
18:57:22 Group 091: Camshaft Adjustment (Bank 1 Intake)
600 /min Engine Speed (G28)
5.1 % Intake Camshaft Bank 1 Duty Cycle
22.0°KW Cam. Adjustment Intake B1 (spec.)
21.5°KW Cam. Adjustment Intake B1 (act.)
18:57:22 Group 155
18:58:18 Group 090: Camshaft Adjustment (Bank 1 Exhaust)
4.7 % Exhaust Camshaft Bank 1 Duty Cycle
-20.0°KW Cam. Adjustment Exhaust B1 (spec.)
-20.0°KW Cam. Adjustment Exhaust B1 (act.)
18:58:18 Group 091: Camshaft Adjustment (Bank 1 Intake)
22.5°KW Cam. Adjustment Intake B1 (act.)
18:58:18 Group 092: Camshaft Adjustment (Bank 2 Intake)
4.7 % Intake Camshaft Bank 2 Duty Cycle
22.0°KW Cam. Adjustment Intake B2 (spec.)
22.0°KW Cam. Adjustment Intake B2 (act.)
18:58:32 Group 090: Camshaft Adjustment (Bank 1 Exhaust)
5.1 % Exhaust Camshaft Bank 1 Duty Cycle
-21.0°KW Cam. Adjustment Exhaust B1 (act.)
18:58:32 Group 091: Camshaft Adjustment (Bank 1 Intake)
18:58:32 Group 092: Camshaft Adjustment (Bank 2 Intake)
5.1 % Intake Camshaft Bank 2 Duty Cycle
Wednesday,14,July,2021,18:59:04:46862
VCDS Version: Release 10.6.0
Data version: 20100630
18:59:01 Group 093: Camshaft Adjustment Adaptation
-4.0°KW Phase Position Bank 1 Intake
Phase Position Bank 2 Intake
-2.0°KW Phase Position Bank 1 Exhaust
Phase Position Bank 2 Exhaust
18:59:01 Group 094: Camshaft Adjustment (Intake)
21.5°KW Cam. Adjustment Bank 1 Intake
22.0°KW Cam. Adjustment Bank 2 Intake
Test OFF Cam. Adj. Test Bank 1 Intake
Test OFF Cam. Adj. Test Bank 2 Intake
18:59:01 Group 096: Camshaft Adjustment (Exhaust)
-20.5°KW Cam. Adjustment Bank 1 Exhaust
-20.0°KW Cam. Adjustment Bank 2 Exhaust
Test OFF Cam. Adj. Test Bank 1 Exhaust
Test OFF Cam. Adj. Test Bank 2 Exhaust
update: carried out a compression test and found the following,
Bank 1;
cyl1 14 bar
cyl2 14.5 bar
cyl3 14.25 bar
cyl 4 14.5 bar
now with bank 2 cylinder 5,6,7,8 all climbed to 20bar and wanted to keep climbing (max pressure on compression tester was 20bar)
rocker cover was then removed to check for broken exhaust cam but it all seems in working order.
is it possible that the chain on bank 2 exhaust cam has jumped a tooth? in vagcom it shows phase positioner of bank 1 intake and exhaust but doesnt seem to show anything for bank 2?
776
871
