I thought that was common knowledge! As it's just a power button.
Edit* On that note if the radio is on and you use the button on the dash to lower the screen, does the music stay on then???
Just be aware that if you turn the MMI system off using the rotary button (held down for an extended time so the screen stays down - you also get a message on your dash to confirm that the "entertainment system is off), then all other MMI features - including the phone - switch off, so if someone rings you, it will ring the phone itself, but it won't ring through the MMI hands free system.
However if you turn the volume down and lower the screen, everything continues to work as normal
No? It's every model...Is it only the saloon that has the dash mounted button for lowering the screen?
Are you quite sure? Certainly you can't make calls with the MMI off (which is ****** irritating) but I thought that a incoming call woke it up.
Yes indeed, turning MMI off, turns it OFF
.... the screen doesn't even open to show reverse camera.
More interesting ...... its not just a rotary knob - its a joystick with SKIP << & >>
Sorry @xBox, this is definitely wrong. If you completely turn off MMI (by holding down the control knob) the screen definitely pops up to show reversing camera when required - at least it does on my car (MY15). I do this a lot.
lol +1 got to give it a go nowI'll try mine later too out of interest ....
