Did you do any more diagnostics other than just the fault code . The actuator is just like a normal vacuum operated item with a sensor on it to provide feedback to the ECU. If the vacuum diaphragm is split or the sensor is faulty that's good. There are many other things that can cause that fault code such as the vanes on the VNT being clogged up or a problem with the valve controlling the actuator. Even a hole in a vacuum pipe or loose pipe can cause issues. I had one of these BV43 turbos on my Passat and if I remember correctly removing the actuator is a bit of a pain as I had to do a lot of tweaking with the adjustment on the rod length. Make sure you measure the existing rod length and set the new one to the same. Otherwise it won't work correctly.
